Old 04-12-2005, 12:17 AM
dr1verdown's Avatar
dr1verdown dr1verdown is offline
Send a message via AIM to dr1verdown
hooking amp up to rear speakers only?
i'm thinking of getting a 300 watt amp and hooking it up only to my rear 6X9 speakers. i asked a guy at work about whether or not it would sound alright and he had no idea so im taking this to the forums. anyone?
Old 04-12-2005, 10:31 AM
kallenbach_05 kallenbach_05 is offline
it would work but just make sure the speakers are able to handle the power that the amp will be giving them so u dont blow them. i have mine hooked up to an amp but i also have subs and they sound pretty good.
Old 04-12-2005, 11:43 AM
dr1verdown's Avatar
cool...i didnt know if it would sound alright at high volume with the front speakers not being amplified
Old 04-12-2005, 11:57 AM
RememberTheAlamo RememberTheAlamo is offline
Send a message via AIM to RememberTheAlamo Send a message via MSN to RememberTheAlamo
Re: hooking amp up to rear speakers only?
Ok, if u have Sony Xplodes they can only handle 80 watts before they blow. If you got a 250 watt amp and some front speakers you could saflty hook all 4 to the amp.
Old 04-12-2005, 12:00 PM
dr1verdown's Avatar
that sounds good....does anyone know the stock wattage of a 2001 GA SE? or is that dependent on the head unit?
Old 04-12-2005, 01:57 PM
scaviola scaviola is offline
Does the car have any tweeters or speakers on the dash? If not, you may find that you can't hear the front speakers at all. In my '93, the front speakers are in the door by my feet - not a good position to produce a proper sound stage. With my rear speakers amplified, I can't hear the fronts at all unless I open the door.
Old 04-12-2005, 05:07 PM
not all sony's are 80 watts. ur pry thinking of RMS which is the minimum wattage they should receive. the higher number is the maximum but never put that much power to them.
