Old 04-11-2005, 11:29 PM
QW13QW QW13QW is offline
Send a message via AIM to QW13QW Send a message via Yahoo to QW13QW
Dead Computer?
1988 Chevy C1500
4.3L V-6
I'm experiencing the same bogging down and stalling out stated in many other threads. However, I have done my research and after replacing nearly every component under the hood, it's come down to this fact. My coolant temperature switch, normally should be at 5 volts, is only at a mere 1 volt !! This is clearly the cause of my computer wanting to modify the air-gas mixture and starves the engine into setting off a Code 44 (Oxygen Sensor). Once the Service Engine Light comes on, she will sputter and die at the next traffic light. The sensor is new and there is a proper ground.
Has my computer decided to up and die or is there a way to restore the 5 volts back into the coolant temperature switch?
UPDATE:
Today I almost couldn't drive my truck to work, so I decided enough was enough, and I unplugged the temperature switch....low and behold the engine jumped to life and ran like a champ again! I tested the voltage going thru the wires again and found it to be at 5 volts solid!
Could my entire problem be a faulty temperature switch that was brand new out of the box???
Old 04-12-2005, 08:48 PM
bad68chev bad68chev is offline
Re: Dead Computer?
you could use an ohm meter to check the switch. Check the resistance reading when cold and then check it as it warms up and make sure it changes
Old 04-15-2005, 10:07 PM
Re: Dead Computer?
Originally Posted by QW13QW
1988 Chevy C1500
4.3L V-6
UPDATE:
UPDATE 2:
I took a voltage/ohms meter and checked the resistance on the coolant temperature switch, both cold and hot and wasn't satisfied with the readings, so I returned the switch to the store for a new one. Ran good for a while and now it's back to running like "poop-on-a-stick".
So I bought a new computer/ECM and PROM for my truck and I am going to switch them out and see if that works. (Wish me luck)
However, someone told me that it's the distributor! He said the magnets in it are shot and the computer cannot advance the timing approprietly.
Does this sound like it "holds-water" for anyone???
Old 04-15-2005, 11:19 PM
jimmydager jimmydager is offline
Re: Dead Computer?
Hey,
I am having the exact same problem as you with the exact same engine. I was wondering where you found the temperature switch on your truck. I figure it is worth a try since I cant find anything else that seems to work. Detailed instructions and or pictures would be greatly appreciated.
Thanks,
Jimmy Dager
Old 04-15-2005, 11:58 PM
Re: Re: Dead Computer?
Originally Posted by jimmydager
Hey,
Thanks,
Jimmy Dager
Right on top of the manifold next to the thermostat. Check out your Haynes or Chilton's manual for your truck. It's fully illustrated.
Good luck.
Old 04-16-2005, 01:45 AM
gremlin96 gremlin96 is offline
yes you can get a bad sencer strate from the maker. worse news is thay pop them out by the thousands so you can repeat the same effect a few times. check the codes on the box if thay are from the same lot there could be a manufactor problem in the sencer.
it could also be a probem with the voltage feeding the sencer. there could be a grounding problem in the system. when you unplug the sencer you will get the 5 volts back. but the system will try to ground thru the sencer when pluged in. if its a ground problem you will get all kinds of strange stuff happing.
the only way to realy be shure is to get a diagram and check all the grounds. add a few if needed. i have found a lot of companys will try to save a penny by not running enuff ground wires. big problems will start showing up latter when thay get durty.
Old 04-16-2005, 03:43 AM
Cam7 Cam7 is offline
The coolant temp sensor electrical connections cause a problem on GMs when they wear. Try using another plug the male end that plugs into the sensor. It will cause the same problem you discribe.
Old 04-16-2005, 09:54 AM
Re: Dead Computer?
Hey,
It ended up being a fried ignition module. If anyone else is having a problem similar to mine, I would deffnitly suggest taking this off and taking it to an auto store and having it tested. It is free and really easy for you to do and could save you hundreds in parts if you just guess and replace parts or take it to a shop. On my truck and similar years, it is located right under the distributer cap. It is held down with two little bolts and has three wire harnesses going to it. just take this piece off and have it tested, might save you lots of time and headache. Thanks for everyones help.
Jimmy Dager
Old 04-16-2005, 06:09 PM
Good to hear it Jimmy!
One down and one to go.....
Old 04-30-2005, 12:37 AM
Re: Re: Re: Dead Computer?
UPDATE: 3
I'm still at it and I'm making progress.
I've replaced EVERY component under the hood, including coil and distributor.
I've checked for vacuum leaks and found none.
I've checked for shorts and found none.
However, I just learned today that the Throttle Body injectors have a final filter screen inside each one!!!
That makes a fuel filter under the truck on the frame, a second at the inlet of the Throttle Body and a final one inside each injector, for a total of 3 inline filters!!!
I'm going in! Wish me luck!
Old 04-30-2005, 01:32 AM
skipr skipr is offline
Re: Re: Re: Re: Dead Computer?
UPDATE: 3
A word of advice. Don't start doing micro surgery on the injectors, the chance of that inline screen being a problem on the individual is very slim. If there clogged, high pressure purge will do the job. And the issue of the solid state ignition module metioned by Jimmy, I never had one or heard of one that went bad gradually. They usally stop you dead in the water when they fail.
Old 05-01-2005, 12:56 AM
mbumgua's Avatar
mbumgua mbumgua is offline
The chevy computer is designed to have a limp home mode when the ignition module fails. The truck will run like crap (richer) but will get you home. Ford and Dodge will leave you on the side of the road when they fail.
Old 05-01-2005, 02:05 AM
Re: Dead Computer?
Perhaps I wasn't very clear about the distributor....I bought a remanufactured one from Advanced Auto Parts. The ignition module, along with the rest of the distributor is new.
Thank you for your input, though. :-)
Old 05-01-2005, 03:23 PM
Fireplug Fireplug is offline
Re: Dead Computer?
Dude
when you unpluged the coolant temp sensor and the engine ran good that would seem to lead you to a ground or wiring problem. Lots of waisted money on parts you dont need
Old 05-01-2005, 07:06 PM
Well.....today I replaced the filters in the injectors and WOW! What a difference! Although the injector filter screens both looked reasonably good, a new set made a world of difference. Now I can see the injectors spraying fuel not just dribbling a mist like earlier.
I hope this is the solution....Check Engine light came on once, probably due to habit(heheh), but the light quickly turned itself off and has stayed off for the rest of the day. Starts and take offs are not a problem anymore.
I hope it stays this way. Thanks to everyone for thier input.
