Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 04-11-2005, 11:11 PM
castillorio castillorio is offline
tires
what air pressure does a 96 taco tire has to have or where it should be
Old 04-12-2005, 05:55 AM
Flash75 Flash75 is offline
AF - Advisor
Re: tires
There should be a label, usually in the driver door jamb with tire pressure recommendations. The information is for standard tires as delivered from the factory. If you have non standard tires the tire shop should have provided tire pressure recommendations. FWIW, I use 33-34 psi in the 205/75/15 tires on my 04 2 wheel drive Xtracab truck. Factory suggest 29 psi. The added pressure does make the ride a little worse but the steering is more responsive with the increased pressure. In any case do not exceed the maximum inflation pressure stamped on the tire.
Old 04-12-2005, 10:00 PM
macanas macanas is offline
Re: tires
It's almost like, what's your preference? I use a little less air in the rear because it's lighter. It also depends on how strong your tires are, loads and factors like what type of driving. If you air up your tires and they look perfectly round, they have too much air, they should have a slight flat spot on the bottom....smoother ride and better contact patch.
