Old 04-11-2005, 10:17 PM
miecow miecow is offline
Send a message via AIM to miecow
90 camaro hell
i just bought a 90 camaro 3.1 v-6, and i'm having a few problems..
it stalls when i hit the gas but not all the time, when it starts stalling it does it alot. i also have no interior lights (gauge cluster, console anything) and half my gauges don't work (tach, oil pressure ) the tach maxes out as soon as you turn the key and the oil pressure jumps around like a skitzo.. this is my third third gen camaro i've owned but it has the most problems... any help will greatly be appreciated
Old 04-11-2005, 10:34 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Alright, I have no idea what it might be but goto www.thirdgen.org it helps you out on almost any problems with your thirdgen maro/fbird, hope it helps out.
Old 04-11-2005, 11:11 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: 90 camaro hell
sounds like a neglected POS... and why did you buy this again?? please tell me you got it for $100. If it's running this bad I'm sure everything else has been neglected, so check everything(oil, coolant, etc).
anyway,
-reset ECU by disconnecting battery for 5mins.
-check that spark plug wires are going to the correct cylinders. (use manual)
-look for wires (in the engine bay) that have been tampered with or heated up severely (by the exhasut manifolds).
-use Haynes repair manual to get the error codes from your ECU (pretty easy), check corresponding sensors according to the manual.
-replace accessory fuse in the fuse box which is located above and to the left of the brake pedal. check all other fuses too, get the fuse tester.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 04-12-2005, 12:39 AM
KaotiKCamaro5's Avatar
KaotiKCamaro5 KaotiKCamaro5 is offline
Send a message via AIM to KaotiKCamaro5
Re: 90 camaro hell
yeah, rather than trying to figure out your problem, im more or less gonna spend my time trying to figure out why you bought a car in such rough shape... pry wasnt the best of ideas..
"doing that is like trying to sell porn to a 6 year old..... It's just wrong" - hypsi87
LE123456712: i promise i will stop filling your email with my boobs
Kieft125: lol.. good, its starting to get rediculous..
Old 04-12-2005, 08:45 AM
Re: 90 camaro hell
yeah.. i got it for $100.. and i bought it for a future 350 swap
