Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-11-2005, 10:03 PM
GURDEV GURDEV is offline
Brake goes to floor
I have cutless cierra 93 i have changed its master clyinder 6 months ago but since couple month it brake padle goes to floor but don't get even hard when you pump.I took it to mech. one said your brake booster need to replaced other said it is just the master clynder i am not sure what to do.Please help
Old 04-11-2005, 11:32 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Brake goes to floor
I know this is a do-it-yourself site but your situation calls for the restoration of your vehicle brakes immediately, as I think you've acknowleged.
Let the one that says master cylinder replacement fix your brakes. Might as well let him check and fix your whole braking system.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
