Old 04-11-2005, 09:52 PM
aquadood aquadood is offline
96 Grand Am 3100
I'm having a problem, was losing coolant, and now it is in oil. How do I differentiate if it is a head gasket or the lower intake manifold gasket failure this engine is (in)famous for? Thank you.
Old 04-12-2005, 05:28 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 96 Grand Am 3100
Do you have steam coming from the exhaust? This is a sure sign of a blown head gasket. You can also pull the plugs and look at them, if there is coolant in the cylinders you should see some evidence on the plugs. A compression test will also indicate if there is a problem. With this particular engine the manifold gasket is where I would start especially if there is water in the oil.
Old 04-12-2005, 08:24 AM
No steam from exhaust, not ever overheated, will check plugs today. Thanks for the input.
Old 04-14-2005, 08:24 AM
Update, it was the intake manifold gasket which had blown. No water in cylinders, and not too bad a fix either, will finish buttoning it up today. Thanks.
