Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 04-11-2005, 09:47 PM
ModifiedCars ModifiedCars is offline
Send a message via AIM to ModifiedCars Send a message via MSN to ModifiedCars Send a message via Yahoo to ModifiedCars
1989 Bronco II
Hey guys, My Bronco has been parked for nearly 2 years, Yesterday we started it up & it is makeing a knocking noise inthe engine, It sounds like thown rod... So I need some help...
How much would it cost to rebuild my Tansmission & Engine?
Would it be cheaper to buy a 5.0 HO Mustang Engine And Tranny & Drop it in?
Old 04-13-2005, 12:43 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: 1989 Bronco II
If your truck has been sitting that long then you may just have a sticky lifter. I would run some good detergent oil through it and see if that helps. Or you could also add a quart of trans fluid to the engine.
Old 04-14-2005, 08:24 PM
Well, the main poblem is the knocking, What are some good detergent oil brands? And where can I get it?
As far as the transmission, its leaking, so we might have to just replace a seal or gasket
Old 04-17-2005, 02:06 PM
Anybody elses input? We're taking it to a shop to let them look at us & tell us whats wrong, and get an estimate.
Old 04-24-2005, 09:09 PM
Truck Truck is offline
Re: 1989 Bronco II
You can check for a thrown rod by using a length of hose/broom handle/prybar as a stethoscope. Place it low on the block (Like where the connecting rods are) and have a listen for the thump. You use the 'implement' to get a better idea of where the noise is coming from.
I don't know about detergent Oil-but I have used Z-Max, and it cleared up my smokey-running BII (1985) for about 6 months. It's a bit pricey at $40-$50 per treatment, but I did notice a difference. When I first bought the thing, I left a trail of noticeable smoke for about a quarter-mile. After I used it, it was gone. When the smoke returned, I was going to do it again, but I sold the thing.
It even has an endorsement from Carrol Shelby, so don't take my word for it.
Old 05-10-2005, 05:03 PM
Re: 1989 Bronco II
yea, it puffs of a blueish smoke, LIke I said, the Truck hasn't been running in 2 years
