Old 04-11-2005, 10:27 PM
mopaco mopaco is offline
Turning and whining
My 05 is whining when turning left about 50% of the time. Of course when i took it to the dealership i couldn't reproduce it. I imaging it to be the belt slipping? What are the common causes? It seems to do it more when i am turning sharp at about about 25 miles an hour or so.
One guy told me that an old farmers trick is to rub soap on the belt so it won't whine. Anyone ever heard of that?
Am I looking the the right general direction here?
Old 04-11-2005, 10:34 PM
jveik jveik is offline
Re: Turning and whining
um hows about a new belt and use a huge-ass screw driver and put as much torque on that mother as you possibly can, then quick tighten it up at the power steering pump and it should have less than i dunno maybe half inch of play when you push down on the belt. at least thats for older models like my 73. you might have some new fangled belt tensioner thingy and a one - belt system. i have a separate one driving the alternator, water pump, and fan clutch, then a second one driving just the power steering pump. another thing is that maybe you are low on fluid or let it get too low and your s.o.l. with the pump. i know a guy that let the fluid get too low and it ruined some bearing inside the pump so its all loud and crud now.
Old 04-12-2005, 12:09 AM
J-Ri's Avatar
J-Ri J-Ri is offline
It sounds like it is a hydraulic issue. If it were the belt, it would do it left and right. Check the fluid level before you drive it again. If it's low, add enough power steering fluid to bring it to the full line. Let it roll (just let it idle in drive) while you turn the steering wheel as far as you can in both directions. Turn it as far as you can both ways about 5 times, then check it again. If the level dropped, bring it back to full, and do the turning thing again. Keep repeating until it stays at full. Don't turn the wheels while it's sitting still, or you'll wear flat spots on your tires.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-12-2005, 12:58 PM
bowtieguy bowtieguy is offline
mine makes a slight whining noice too,but it is only once in a great while and when i am turning my wheel fast for whatever reason. i guess the pump cant keep up with the demand when turning wheel that fast?
2002 Z71 ext. cab LT trim
badgeless
Rhino spray in liner
Stock for now, other than free mods
future plans (how far in the future depends on wallet)
Toyo Open Country M/T's
air intake (not sure which yet)
exhaust system (seems that Magna flow is the ticket)
Nelson tune
3 or 4 inch lift
Old 04-12-2005, 07:57 PM
gremlin96 gremlin96 is offline
i would try the belt first.
I have a 04 4x4 it done it last summer, and in the winter the auto tenser gave out. the bad news is its doing it agen.
Old 04-12-2005, 11:56 PM
miltystu miltystu is offline
If its the belt it will screach. if you get a whining noise it is a pump issue. I agree with checking fluid as described earlier. If that doesn't help bring it back to the dealer and raise hell.
2005 Silverado 4x4 Crew 1500 5.3
Alpine deck, Alpine Type-R componant front and rear, Alpine Type-R 10" sub under rear seat, 2 JBL amps
Corsa cat back Duals
K&N FIPK intake
Superchips MAX Microtuner
:22yikes: " IM BROKE"
Old 04-13-2005, 10:54 AM
chuck16's Avatar
chuck16 chuck16 is offline
I have a 99' 1500 and the Power Steering pump was replaced by the previous owner as apparently it exploded and died on him. The new one seems to be a bit whiny but the fluid level seems to be ok....
Thank god it's not as whiny as all Ford Power Steering Pumps..
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 04-13-2005, 01:04 PM
TXAGG05 TXAGG05 is offline
'02 Z71
On occasion mine will screach like it's the belt,....but only on left turns and only every once in a while, like when I turn left at just the right speed.
Jeb
2002 Chevy Z71 Ext Cab, Black
2004 Blue Wave 180-V, 90hp Yamaha Outboard
Pre 1960 Duck Boat, 9hp Mercury Outboard
2002 Argo Conquest w/ tracks
Also driving, but not at my house:
2001 Pierce Saber
1989 Pierce Dash
(See Pics in my gallery)
