Old 04-11-2005, 09:12 PM
niquette niquette is offline
Thumbs down Engine power loss
Chevrolet Lumina APV 1996 : I have experience an intermittent problem.
3 things happen at the same time,. First problem, taking off with the transmission in drive position the engine revolution was unstable than the transmission stayed in first gear and at the same time notice that I lost power from the alternator. I suspect these may be related to a commend use can anyone help.
Thanks,
Niq
Old 04-13-2005, 09:33 PM
k5dan's Avatar
k5dan k5dan is offline
Send a message via Yahoo to k5dan
Re: Engine power loss
if the alternator isn't working properly then it could cause your problems especially on a GM product.
-->1994 Ford Thunderbird LX 4.6l V8, auto trans. Completely Stock
-->1989 Dodge Dakota 3.9l v6, 5 speed manual trans, 4x4
Old 04-14-2005, 08:16 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Yep. You've got a solenoid activated tranny, they wont shift right (or shift at all) if the voltage is too low. Some will just go to second gear and stay there, if the problem is real bad.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
