Old 04-11-2005, 08:29 PM
toenailclippers toenailclippers is offline
Send a message via AIM to toenailclippers
Talking The SS-10!!!!
ok, ive asked a couple questions and have only gotten a small amount of feedback. (thanks for those who gave me some). IM planning to do a 400 small black swap backed with a TH350 transmission into a 87 s-10 extended cab short bed 2wd. can someone give me a website where i can get the new motor mounts? also, what kind of rearend am i going to need? can i just pull one out of another truck and put it into the s-10 without TOO much modifications? one more thing..how am i going to hook up the old witring harness to the 400? anyone who has had experiance with this or knows anything about it PLEASE HELP!! im on my way to building an SS-10, something to put mustang 5.0's into the dirt! thanks!
Old 04-11-2005, 09:13 PM
16th hippy 16th hippy is offline
might not be able to use the old wiring harness....depends on what the 400 has...carb\f-i. might be better to get an ecu and wiring harness for the 400 if possible.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 04-11-2005, 10:36 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: The SS-10!!!!
you will want all the stuff from the sb, brain box, ecm, wireing harness, most likely a better fuel pump, keep it with the f/i if it has it, most likely you will run across a carb moter, and that will be fine, but you will still need all computer stuff from the 400
Old 04-11-2005, 10:47 PM
OverBoardProject OverBoardProject is offline
Banned
Re: The SS-10!!!!
Advanced adaptors makes the motormounts for the swap. There pricy. www.advanceadapters.com
Most people just use 2.8L s-10 motormounts, and make an adptor to fit the motor.
The 7th photo on that waeb page that I gave you shows how he made his
http://hickory.engr.utk.edu/~gpowell/2.html.
Painless Performance would probably make you up an adapting wire harness, but you can probably get an 82 - 85 carburated wire harness and adapt them to the application.
www.painlessperformance.com
About the rear end. You should be fine with the stock rear end. All that I would do is change the axles to aftermarket axles, and if your still nervous about it there is a bearing kit that will allow you to use the rear end guts from a V8 comaro. My mechanic friend did it to his 500hp Vega. He ran a stock rear end with aftermarket axles for years with that much power, problem free (with slicks on... they don't spin they break axles or twist drive shafts).
I saw my mechanic friend today, but he was too busy to ask about what cars to look in for the motor and transmission.
I have to see him tomorrow and he will hopefully have more time
Old 04-12-2005, 07:30 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: The SS-10!!!!
Also look at www.jagsthatrun.com they will have everything needed for the conversion
Old 04-12-2005, 01:47 PM
Re: The SS-10!!!!
ok, its 109 bucks for themotor mounts, but now the question is....A/C or no A/C?
Old 04-12-2005, 02:41 PM
Banned
Re: The SS-10!!!!
That really depends where you live, and what you want.
Where I live, in the hottest part of Canada I could really use air about 3 - 4 months a year most years but I just put up with it, and do most of my driving after dark.
If you live in California you probably want it.
It's tough to fit everything under the hood with air, but I'm told that it will fit
Old 04-12-2005, 06:42 PM
Re: The SS-10!!!!
i live in virginia, so its not that nessecary. ill be crusing ith the windows down mst of the time anyway. what about the rearend? can i pull one out of a fullsize truck and put it in the s-10with no problems?
Old 04-12-2005, 07:57 PM
Banned
Re: The SS-10!!!!
Like I said, a friend of mine ran 500hp on a S-10 rear end. He only changed the axles to aftermarket.
Unless you run NOS I don't think that you'll have to worry about the stock rear end.
If your worried just beef up your exsisting rear end
I'll ask my friend as soon as I can if he can tell me who he got his parts from. He used a comaro 8.5" guts in his chevy s-10 7.5" rear end by just using special bearings
