Go Back   Automotive Forums Car Chat > Dodge > SRT4
Old 04-11-2005, 07:35 PM
solomontomb's Avatar
solomontomb solomontomb is offline
Send a message via Yahoo to solomontomb
20 psi boost?
hey everyone i hooked up a maual boost controller to my 2004 dodge neon srt4 turbo,the only modifiacation i know of is the upgraded exhaust system it doesnt have any stage modifications(stage 1 or stage 2),but its spiking to 20 psi of boost even when i turn the boost all the way down! i hooked the green line to the turbo, the black line is capped,the mbc tied into a t and the t is tied into a blue line which is tied into the turbo. when do i get fuel cut and is this safe? how do you know if you have stage 1 modifications..and why the f!@# is it spiking to 20 psi of boost!! the reason why im asking this question is because i bought the car used and im not sure if the guy modified it. so any help will be great.
Old 04-11-2005, 09:11 PM
TEXSRT4 TEXSRT4 is offline
Re: 20 psi boost?
what wastegate is on there? you shouldnt be spiking to 20 without having atleast stage 1. i would take it back to stock and try it again, it sounds like you have an vacum leak that is altering your wastegate signal
Old 04-12-2005, 01:45 PM
Question Re: 20 psi boost?
everything is stock,stock bov,stock wastegate. im not sure why its spiking. i have another question should i remove the bleeder hole on the mbc of leave it, if it goes 20psi of boost and im not getting any fuel cut does that mean i got stage 1 modification? i really apperciate your answers..thanks
Old 04-12-2005, 10:31 PM
Re: 20 psi boost?
you wont notice a fuel issue, you wont feel it but that doesnt mean you arnt going lean. do a check for codes, if you have stage 1 it will tell you. go to www.srtforums.com and do a search for stage 1 CEL. the boost controller is why your spiking boost
