Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-11-2005, 07:05 PM
firestar497 firestar497 is offline
Question 93 Mustang
Turn signals do not work . Changed switch . All fuses good . Hazards work , Head lights work . What can it be ?
Old 04-11-2005, 07:53 PM
ladytex70 ladytex70 is offline
Re: 93 Mustang
I had the same problem but it end up that the switch was loose in the steering colum. I know that you said that you changed it out. Did you make sure that the bulbs were good. Some times they have two filaments and one of them be burnt out.
Old 04-11-2005, 08:27 PM
Re: 93 Mustang
All bulbs have been changed . Can you suggest anything else ?
Old 04-11-2005, 08:52 PM
Re: 93 Mustang
Theres a big sliver fuse that is the fuse box. There isn't a way to check it I would just replace it. It cost something like 3.99 or so.
Old 04-12-2005, 02:47 PM
Re: 93 Mustang
I will try it . Thank You for your help .
