Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-11-2005, 06:37 PM
mikeb55421 mikeb55421 is offline
rain = no start
i got a problem, my buddies car won't start when it rains. he has a 1994 caprice with the 4.3 v8. he recently had his distributor repaced, and he thinks thats the problem. myself, i have no clue what is up with it. any ideas would be helpful
Old 04-12-2005, 06:52 PM
flip1ky's Avatar
flip1ky flip1ky is offline
Re: rain = no start
I have a 92 that does not like water.... rain, car wash.... What i was going to try is taking a spray bottle and see where it starts missing. Distributor can cause it to run rough when damp, Did trouble start after it was replaced?
Old 04-14-2005, 10:00 AM
chaney3000's Avatar
chaney3000 chaney3000 is offline
Re: rain = no start
Does the car have an engine compartment leak? Just spray the front of the car and the hood with a water hose to see if the engine compartment is leaking really bad. Because the only way the car is going to die from water is if the distributor or the injection is getting wet.
Old 04-15-2005, 09:38 AM
ladymech62's Avatar
ladymech62 ladymech62 is offline
Send a message via Yahoo to ladymech62
Re: rain = no start
Water can condense in the distributor cap. Slip the cap off and look for water beads inside the cap. You may even find a carbon track (black line) running from the button in the center (coil) to one of the screws that holds the coil in the cap. This grounds out the coil and you won't get fire. Some are just that sensitive to moisture.
Chased a car that if there had been a heavy dew it wouldn't start!
Cheryl . . . Mom, mechanic, and gopher
1, 8, 4, 3, 6, 5, 7, 2 What do you mean I can't use that on a FORD?
