Old 04-11-2005, 06:34 PM
Hpnotiq86's Avatar
Hpnotiq86 Hpnotiq86 is offline
Send a message via Yahoo to Hpnotiq86
Loud popping noise, when I open the door.
Its so loud and embarassing, when the door is ALMOST half-way open, it goes 'Errrr-POP!'. Also, it sometimes will make a weird sort of, barking sound, and creaks from the time I open it, to the time its all the way open...and back again, also with the loud POP! in the middle.
Anyone know why? Do I just need some PB Blaster, or WD-40?...
Old 04-11-2005, 07:53 PM
lukedogg8706 lukedogg8706 is offline
Re: Loud popping noise, when I open the door.
WD-40 will for but for a couple weeks, you need to replace the part, its what connects your door to your car, same thing happend to my car, but I never fixed it. I just kept spraying it.
98 TSI AWD
Old 04-12-2005, 12:37 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
try spraying some graphite lubricant where your door pivots. that might cure it for awhile.
95 Talon TSI AWD
97 Eclipse GST
Old 04-12-2005, 05:26 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
I used some "green slime" the stuff used for grease xerxes and stuff... as for the popping.. my car did it and it was the connection from the door to the body that was getting worn out with about 1/16" - 1/8" play and when the tension released it "popped"... I just lived with it...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 04-12-2005, 07:23 PM
slowgsowner slowgsowner is offline
I had this problem and so do alot of others simply look at the hinge area there will be a black bar connecting door to body with some brass colored nuts holding this to the in side of the door , open the door half way and take some locktite to the threads of the nuts and tighten them down. tight
95 gs booosted ....no time yet
99 gsx stock
71 mustang 429cj...9.94
84fiero/diablo conv. in proggress
