Old 04-11-2005, 07:32 PM
joshua19_21 joshua19_21 is offline
LXi Question
I just bought a 1989 Honda Accord LXi, it was pretty cheap and was working at the time. But when I got it home, it no longer worked. Here's what happened. The guy let it get down to the last little bit of gas and probably clogged the fuel filter-so I changed it, then the batter died-got a new one. then the alternator was incorrectly posistioned and the belt made a terrible screeching noise-so I reposistioned it. It worked finally. But now it is being slow to start. The engine turns over nicely but it doesn't want to take that last step of starting. Does anyone have any ideas? Thanks!
jt
Old 04-20-2005, 03:05 PM
slipknotcraig133 slipknotcraig133 is offline
Send a message via AIM to slipknotcraig133
Re: LXi Question
Check to see if you are throwing any codes. My 86 LXI did the same thing. Also check fuses like the fuel pump fuse. Check to see if you are getting spark and fuel.
Got the car 1400
Need an H22a4 4000
Some Goodies to go Along With it 2000
Some Drag Slicks 750
Going to the Strip and Make V8's Say D*** Hondas PRICELESS
