Acura Legend, 1990
I've got a problem with my old Acura Legend.... Darn things got 237,000 miles..... It's a V6 and the center two cylinders aren't firing...... I know that by pulling the spark plug wire while it's running... Doesn't change the idle.
The spark plugs are good, pulled the offending cylinders wire and put a plug on it... Sparked up good....
The wires are good, wouldn't of got a spark otherwise.....
Swaped the injector with a know good one.... Problem persisted....
Used a noid light to verify the injector is getting signaled.....
Checked compression...
I'm outta idea's.... you need three things in an internal combustion engine... Fuel, Fire and compression.... I've got all three... but I must be missing something.... Maybe that injector really isn't firing....
I really want to push it into the mississippi...
