Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 04-11-2005, 05:47 PM
smitsz1 smitsz1 is offline
ticking/chattering noise under passenger side valve cover...
Does anyone know if this is the valve lifter sticking. It started a couple of weeks ago but only did it occasionally after you started the truck up and would go away in under a minute. Now it seems to make the noise every time it starts and it is noticeable driving down the road for the first couple of miutes. Temperature outside does not seem to be a factor anymore.(first occurred when it was extremely cold outside.)
Old 04-11-2005, 10:11 PM
Eggert Eggert is offline
Re: ticking/chattering noise under passenger side valve cover...
Hi,
yes, that could be a bad hydraulic valve lifter. Please have this checked out soon before there is more / permanent damage.
Take care, Eggert
Old 04-22-2005, 05:57 PM
STUBBORNM STUBBORNM is offline
Send a message via AIM to STUBBORNM
Try Some Motor Flush This Will Help Remove Carbon Build Up And Allow Oil To Lubracate Better... Use Good Oil Like Castrol Gtx
An Engine Additive Might Help Also.
Old 04-30-2005, 03:56 PM
additive added
I use castol gtx. Also I have added a additive such as "restore" to the engine. The problem went away for two weeks and as of yesterday it is back. Also since yesterday my engine light is on steady???
Old 05-01-2005, 07:15 PM
Hi, can you read and post the diagnostic codes?
Take care, Eggert
