i was told that my fuel pump relay might be bad but i dont know where it is located can anyone help with this issue.
thanks
1991 RS 305 T.B.I. 700-R4
the fuel pump relay for the Forth Generation Camaro's is on the left hand side of the driver's footwell, under a plastic cover. If you have a 5 speed, put your foot on the clutch pedal and then move it to the left, you should hit the cover. Good Luck!!
Jack
before: ![]() ![]() ![]() ![]() after:
Re: fuel pump relay
thanks but does anyone know where it is on a third gen
Well for me it was next to the engine, like where the passenger side is, just try to find the part that looks like to it.
Re: fuel pump relay
Should be the relay on the passenger side firewall right next to the A/C. Hopefully you know what a relay looks like. There are also 2 other relays on the drivers side firewall. I know one of those is for the Fan, and other stuff.
I may be mistaken but I believe that your fuel pump relay should be:
UNDER HOOD, DRIVER SIDE, REAR ENGINE AREA, DRIVER SIDE OF MASTER CYLINDER, MOUNTED ON FIREWALL |
Re: fuel pump relay
He is exactly right. On an 86-89 third gen there will be 3 relays there, fuel pump, MAF power, MAF burn off.
Re: fuel pump relay
On my 91 there are 2 on drivers side firewall, and 1 on passenger side firewall. Fuel pump relay is one of the ones on the drivers side.
Another thing to note if your not getting fuel while trying to start up there could be several other reasons for this. If the computer thinks there is not enough oil pressure it will cut power to the fuel pump. Among many others. Last edited by jaime_cartero; 05-27-2005 at 08:02 PM. |
Re: Re: fuel pump relay
