Old 04-11-2005, 03:26 PM
riccbhard riccbhard is offline
A/C Parts
I have the following air conditioner parts for my 1968 Camaro:
• Compressor
• Accumulator
• One of the hoses (not sure which)
• Condensor
P.S. - The blower is disconnected.
Could you tell me what else I need to install an A/C system? It is getting VERY hot here.
I also have another question for an 1989 camaro, but I though that since it's so simple and general I figured I'd keep the board clean and not make another topic. Anywho:
Is the engine temp. susposed to run near 220 degrees F.?
It seems this is a little high. It has a V8 305.
Thanks for your help!
Old 04-11-2005, 04:30 PM
tcfco2005 tcfco2005 is offline
Re: A/C Parts
ya 220 is alright most engines dont turn the fan on till 225 so thats about right. as for your other question i dont know sorry man
1991 RS
305 T.B.I.
700-R4
Old 04-12-2005, 11:00 AM
ctskier ctskier is offline
my 86 camaro iroc still uses freon for the a/c. I am gonna convert it soon so i cana stop using it. When i take mine apart ill tell u.lol might be a while
Old 08-14-2005, 06:35 AM
gearhead74 gearhead74 is offline
1968 A/c
I made all the A/C hoses for a 67 Camaro about two years ago for a customer. I used Barrier hose so he could run 134a. He did however have to use worm clamps at the condenser. It has a barbed fitting and I could not use a compression fitting to couple to it.
Old 08-14-2005, 07:24 AM
CamaroRS92 CamaroRS92 is offline
Re: A/C Parts
You'll also need an evaporator, orifice tube or expansion valve (not sure which was used on that model) , high pressure cut off switch, low pressure cut off switch
