Originally Posted by bluehaze13
I'm looking to replace the headlights bulbs for my new 6. But as you know there is a dim light bulb, and a bright light bulb. Where am I going to find xenon bulbs or any other performance bulbs? All the H1 bulbs that I've found have the bright/dim combo. Help me please!
It's simple as pie. Lift up your hood, unconnect your battery, behind your headlights (on the driver side you'll see the air box {if you still have it} and a rubber backing with a little tab on it. Push on the tab, not too hard, and it'll pop off. Then you just need to recognize where the bulbs are. If you want brighter bulbs but don't want HID's go with a H1 for the brights and the low beams (I used diamond blues, but the aren't any brighter {they also have super whites}) I also put an H3 super white for the fog lights (assuming you have them). You'll see a silver pin that holds the lights in place, just unclip that (it is a j clip) and replace the bulb. The passenger side is a lot more difficult because you have to work around a lot of tight spaces. I took off the resivoir that was there for more room (use a 10?mm socket wrench) and the percedure is the same. After you're done, and before you put the back on make sure your lights work. After you see that they work put the backs back on your assembly and put the resovior back in. Taadaa.. you're done! (Trust me it seems more complicated that it is, but I'm a mechanical midget and was able to do it in about 1/2 hour)
