Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 04-11-2005, 02:30 PM
SmicAA72
Guest
Posts: n/a
Body Kit installation
Hey everyone. Well Ive been looking for a picture or anything like that showing where all the bolts and screws should be for all 4 stock bumpers. Does anyone have anything like this. I am gonna attempt to begin to install my body kit that I am picking up today, and it would really help if someone had rough pics they can post that show where all the bolts are. Thanks.
EDIT: Its in my sig, but its a 99 Gs.
Old 04-12-2005, 09:26 AM
RSLaser RSLaser is offline
Not all kits/bumpers will just bolt up the same. Usually the holes are not predrilled for best fit. Best way is to take off the stock bumper and set it on there and make your marks witha sharpie marker, then drill.
1991 Plymouth Laser RS
Only sat for a few years....
Old 04-12-2005, 03:15 PM
SmicAA72
Guest
Posts: n/a
Re: Body Kit installation
Well mine isnt pre-drilled. Im talking about existing holes in the car that you would bolt the body kit to. Like where all of the holes are that your stock bumpers are being held on with.
Old 04-12-2005, 03:34 PM
--- --- is offline
When you take your stock bumper off you'll see the mounting holes in the bumper. Just measure those and drill.
I drive a slow car.
Old 04-12-2005, 04:27 PM
SmicAA72
Guest
Posts: n/a
Can I use any drill, like a drill I would use on wood or something? That should be fine right?
Old 04-13-2005, 09:37 AM
Dont use a wood padel drill bit.lol Use any common steel bit, make sure its gonna hold the bolt snug though, dont want any rattling.
Old 04-13-2005, 02:54 PM
SmicAA72
Guest
Posts: n/a
wood padel drill bit? The ones I got are steel, like a regular bit. Thats fine then? And do you have any special techniques for measuring the wholes, or should i break out my measuring tape.
Old 04-13-2005, 03:59 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
You might want to invest in one of the tapered unibits (I don't know if that is the proper name or not).
It is a stepped bit that will enlarge the hole from 1/8" to 1/4" to 3/8" etc. Really nice to have around.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-13-2005, 07:58 PM
SmicAA72
Guest
Posts: n/a
Obviously first time Ive attempted to tackle this, but why would i need to enlarge the holes?
Old 04-13-2005, 08:06 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
its just to drill the holes in the new bumper. since it starts with a small hole it's smoother and isnt as likely that the bumper will crack
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 04-13-2005, 08:40 PM
SmicAA72
Guest
Posts: n/a
ooooOOO now I understand. I do not think the bumper is likely to crack tho, as it is poly. But, you never know. With luck like mine, anything is possible. Also, when bolting the kit on, is it like a nut and bolt type of application? How will I get up and around it to apply a nut on the other side?
