Go Back   Automotive Forums Car Chat > Buick > Century
Old 04-11-2005, 01:17 PM
Yoxy99 Yoxy99 is offline
Slight Rust spot
I have a 1994 buick century and I am beginning to have a slight rust spot behind my drivers side front tire and I was wondering what i could do to make it look about as new as possible but not having it to take it to a body shop because the rust spot is not that big. It is starting to peel a little paint and i do not want the rust to get out of hand and i would like it to look normal. please help
Old 04-19-2005, 07:01 PM
jibbijib's Avatar
jibbijib jibbijib is offline
Send a message via MSN to jibbijib
Re: Slight Rust spot
Do you have access to a grinder? If so, you can grind down the spot and a little over the flaked spot. dont push hard. grind until you see shiny metal, which shouldnt take long. after that, take some 320 grit sandpaper to it with a sander on the bare metal spot. mask a squared off area about 5 inches around the spot. and mask off the edge of the door. take 500 grit sand paper to the paint and sand it untill it turns white and there are no orange peel effect happening. (youll notice there will be tiny dark spots in a orange peel texture, sand untill not orange peel is left.) when you get it all sanded, clean it off. put some newspapers up on the masked off areas, make sure you cover ever spot. if you miss tiny spots, use tape. Set some Dupont Primer and spray the area untill you cant see the metal any more. use side to side strokes. when the primer is dry. use colour matched paint and spray it over in the same fashion, but apply two coats.get clear top coat and do the same thing, applying two coats. take off your masking and presto, new car!
