Help identifying switches
I just bought a 1997 Passport with an automatic. As the truch did not come with the owners manual, i have no idea what the "POWER DRIVE" and "WINTER DRIVE" buttons on the center console do. I have tried searching the net, but its hopeless. Any help is appreciated. Thanks.
Re: Help identifying switches
Pushing the "Winter" button causes your vehicle to start off in 3rd gear. Winter mode is deactivated when the vehicle reaches 19 mph or you place the shifter into any position but "D".
2000 VW New Beetle TDI 2007 Honda CR-V |
look in the FAQ page!!!!!!
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k |
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
The FAQ is correct on the Winter Drive button. On the Power Drive, it delays upshifts and downshifts, essentually holds gears longer before shifting. It also increases the line pressure in the transmission. Increasing line pressure provides greater clamping ability of the clutch packs and converter clutch when applied. This mode is for towing or hauling. Constantly shifitng under load and towing/hauling generates more heat as the friction materials slip as they engage under load. This mode helps to reduce the amount of heat generated which keeps the fluid alive and increases the life of the transmission.
suvguy '00 Rodeo LS 4x2 3.2L auto Quote:
