Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-11-2005, 11:25 AM
f250e350 f250e350 is offline
Missing + Trans Problems
Recently my check engine light came on.....codes 42+43 came up......My truck now misses while you drive it + when my i accel my trans will shift through all gears fine except when it gets into the final gear....when it shifts up into the final gear is shakes the whole truck...like you are going over mini-speedbumps....i am wondering if these two are realted.....if not....then do you have any suggestions??? pls help 97 dodge ram 1500 automatic 4x4 5.9 V8 gas....oh yeah if you turn off overdrive the truck wont shake
Old 04-11-2005, 11:53 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Missing + Trans Problems
code 42- ASD (Automatic ShutDown) relay shorted or open condition detected.
code 43- misfire detected in one or more cylinders
Now wouldn't be a bad time to do a major tune-up, plugs, wires, cap, rotor, fuel filter, etc.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 04-12-2005, 09:39 PM
Furdog Furdog is offline
Hey Check out my post Dodge ram shaking like a mother $%&#
Change you plugs wires cap rotor. that should do the trick
Old 04-13-2005, 06:32 PM
Changed plug wire + spark plugs.....not a difference....any other suggestions??i am changing the cap and rotor next.....what else might it be....fuel filter??....maybe fuel pump starting to go out???? any other suggestions than the ones above?
Old 04-13-2005, 07:20 PM
Replace the cap and rotor next... That might just due the trick Cap $8.99 rotor $3.99 Get you Some!
