| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
narrow band a/f gauge
can i tune my safc 2 with a digital narrow band A/F gauge, not the one with the blinky lights, this one shows the voltage. if so what are some good numbers i read .88v-.92v, is .88 to lean? and the leaner, the hotter, but more power?
thanks tyler |
Re: narrow band a/f gauge
mmm....never heard of that being done....you will get the best results with using a wideband
Need a GOOD 6-bolt engine? Quote:
'95 Talon Tsi EVO III GT, supporting mods, not running Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped. |
The narrowband o2 sensor voltage should be used as a very rough source of data only In other words, just use it to make sure everything is in check and that you're not completely off the map. Don't use it solely to do any actual tuning, though. .88v-.92 is definitely on the map, so you have no worries. FWIW, I hardly pay the narrowband front o2 any attention at all when I'm tuning. Just use it to make sure you're in the ballpark
![]() 95 GSX DSMlink, "50 Trim", and track times coming VERY SOON!
See www.posracing.net/afr.html for my thoughts on narrowband O2 sensors. While the digital readout is more useful than the blinkylights, it is still only as accurate as the sensor itself.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
