I have a 95 ford Probe GT with rear disk brakes. I am trying to change the rear pads but I cannot get the parking brake loose. I have turned the brake adjustment nut but it is not loosening the cable enough to release the cable from it's fitting. Is there a trick to doing this? Does anyone have a suggestion?
Re: 95 Ford Probe Brake Question
if u haven't done this before you might want to take it to a pro before u mess something up, but if your determined to learn how ot do it your best bet is to pay 15$ and buy the manual, and it tells you what you have to do.
93 FORD PROBE GT JDM manifold ported match 65mm TB Unorthodox Underdrive Pulley Hotshot headers 3' Exhaust all the way No cat Cold air intake K&N air filter Short throw shifter Eibach lowering springs FX Design Body Kit B&M Short Shifter Stage 3 Clutch MX-3 Flywheel Performace Wires and Plugs Synthetics Performance Rad and fan Mild Weight Reduction Coming this week: Performance Heads and Cams 3 angle head job Why does everyone have to piss on Ford.
Re: Re: 95 Ford Probe Brake Question
Thank you for your reply, however, I already have the manual and my problem is that it is telling me to turn the parking brake adjustment nut and release the cable. I have turned the nut a lot and the cable is only slightly loosening. What could be stopping the cable from loosening?
do u have the break on, if you do it wont release
No, I have the brake handle all the way down. Do I need to release anything under the handle?
u shouldn't have to remove anything at the handle, i really dont know in this case, um, maybe just trying to pull and turn, with some dw-40 on it. But let me find something i can find on the net to help me, hang on a sec
i dont think you have to remove the emergency brake line but im not sure but this site might help you out a bit
http://www.edmunds.com/ownership/how...7/article.html
Thanks for the link. Unfortunately it only talked about the front brakes and I did those last weekend. I will try some WD-40 but I haven't sees any open areas to spray the cable.
good luck
I now this is a day late and a dollar short, but it may help someone else.
For the rear brakes you do remove the E brake cable so you can rotate the caliper, you have to pry the lever back to unseat the cable because the caliper has a spring on the lever to keep tension on it so it won't just come loose when E brake is not applied, after changing pads, replace cable end on lever first, then pry back again to seat other part in brace. you don't have to loosen any nuts or anthing this way and your E brake stays set correctly |
