Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 04-11-2005, 07:39 AM
AnotherNewbie AnotherNewbie is offline
Interior painting help
Alright, its already been discussed, i just have a few questions i couldnt find answered anywhere else.
First off, I'm painting just about everything, door panels, center counsol, dashboard, all trim on the interior.
My main questions are:
1) will regular primer for plastics work as my base coat(this is going on vinyl too.
2) will 400 grit sandpaper work for my between coat wet-sands?
Everyone calls for 1000 grit, i've never seen, nor can i find at any store 1000 grit... 400 grit fine, is pretty subtle...
Any suggestions would be appreciated, ima take pictures today of my progress.
Old 04-16-2005, 06:34 PM
riccimangan riccimangan is offline
Re: Interior painting help
You should ask someone inthe paint shop about the primer,Thats the best place to go.
as for the sandpaper P1000 is the right paper to use for flatting between coats, the paint shop will be able to give you more info on that too.,,.,.,
Old 04-26-2005, 11:15 AM
Aperson Aperson is offline
I painted my interior a while back. The plastic primer worked well on the plastic parts. For the vinyl though I ended up using the G2 vinyl dye, www.g2usa.com. Was more expensive, but worked way better than anything else I tried.
_____________________________________
"If you stop to listen to all the advice in the world, you'll end up doing nothin." -Aperson
Old 04-26-2005, 08:47 PM
Was the dye glossy? I'm hoping for a universal look, glossy
Old 05-03-2005, 01:29 PM
I used flat black all around then put in brushed aluminum interior trim, came out really nice.
Old 05-16-2005, 12:15 AM
henry matyjewicz's Avatar
henry matyjewicz henry matyjewicz is offline
sounds nice. got pics of that?
"Nonviolence is the greatest force at the disposal of mankind. It is
mightier than the mightiest weapon of destruction devised by the ingenuity of man"
Mohandas K. Gandhi
