Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 04-11-2005, 01:31 AM
Omega7 Omega7 is offline
Ticking noise
I have a 99 civic lx, and there is a ticking noise coming from the engine, if I rev the engine up it ticks faster, I was told this is just the sound of my engine turning over. Is this true or is it something else? and can I fix it? Sometimes after my car has been off for awhile and I start it, it does not make the noise, but it start making the noise after I drive it for even a short period of time. Cold/warm/hot weather does not affect it.
Old 04-11-2005, 01:47 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Ticking noise
mileage? last time you had a valve adjustment?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 04-11-2005, 02:00 AM
Re: Re: Ticking noise
close to 69k miles, I've never had it done, owners before me, no idea. I've had it less than a year I think, it had 56k miles on it. Don't remember it making the noise when I bought it.
Old 04-11-2005, 10:23 PM
The noise seems to be getting louder. Someone has to have some info on this!!
Old 04-11-2005, 10:28 PM
Valvetrain ticking noise. Some Ohio-built 1995-97 Accord LX and DX models may exhibit a ticking noise coming from the valvetrain. The cause could be excessive intake rocker arm shaft clearance at the No. 2 cylinder.
To zero in on the diagnosis, measure the clearance of the No. 2 cylinder intake valve closest to cylinder No. 1. If the clearance exceeds .40mm, replace the cam holder (Part No. 12010-POB-305, H/C 5686423) and the adjoining intake rocker arm shafts at the No. 2 cylinder. If the clearance is less than .40mm, adjust the valve clearance to specs (cold), then see if the adjustment screw threads are visible above the locknut. If they are, you're done. If the threads aren't visible, replace the cam holder.
Hmm, could this be my problem? Even though my car is a 99 civic lx.....hmm anyone? lol
Old 04-12-2005, 01:13 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Ticking noise
Like superbluecivicsi said, it's probably your valves. Get them adjusted.
Empty Pockets Racing Member #1
Old 04-12-2005, 01:07 PM
Do I need to have them adjusted or can I do it myself?
Old 04-12-2005, 01:30 PM
AF - Advisor
Re: Ticking noise
you can pay the $70 to get it done (the cost of 1 hours worth of labor) or you can do it yourself. you will need feeler gauges.
Old 04-12-2005, 01:39 PM
Alright, been reading through the chilton book, in this book is it valve lash adjustment that your talking about?
Old 04-13-2005, 04:24 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Ticking noise
yes thats it
Old 04-15-2005, 02:59 PM
MODIFIED_GSR MODIFIED_GSR is offline
Re: Ticking noise
i think you engine is gone bud same thin happend to me and i thought it was the valves. turuned out the next mournin to work my engine blew clouds of smoke all over the hig way. but now i got a b18c1 so im alllllllllll goooooooood lol . as you drive do you hear the noise gettin louder and faster
Old 04-15-2005, 10:31 PM
AF - Advisor
ticking heads that ive seen went away with a simple valve adjustment. maybe yours is an isolated event.
just do the valve adjustment first. that is step one.
