Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 04-11-2005, 12:56 AM
jet41989 jet41989 is offline
Question tail light removal help
this is probably a stupid question but i bought red-clear tail lights for my 96 2dr civic. the problem is i dont kno how to remove the old 1s. which bolts do i unscrew, any help is greatly appreciated.
Old 04-11-2005, 09:34 AM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
Re: tail light removal help
there are 3 bolts on the back of the inner tail lights, and u have to remove the carpet behind the outer lights and remove the 4 bolts. simple enough
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 04-11-2005, 04:50 PM
thank you for the help, but i see the 1 bolt on the inner tail light but cant find other two, and does it just come off after the bolts are off? and also are there any leakage, sealage issues i have to b concerned with? sry for the ignorant questions, kinda new to this
Old 04-11-2005, 05:01 PM
gdriver gdriver is offline
once the bolts are off, you have to unplug the lights before you pull out the cases because the wires dont have very much travel. the lights won't just fall out or anything once the bolts are off because there are plastic studs that go into guide holes and keep the ligts from coming out without you taking them out. as to the leakage, i know mine have a leak somewhere b/c any time i wash my car i get condensation on the inside of my outer lenses.
Old 04-11-2005, 07:58 PM
thank you, that was very helpful. about the plastic studs, how do i got about moving those? do i have to b careful with them and will i still need them?
Old 04-12-2005, 03:31 PM
and also, is there any to prevent the leaking?
Old 04-12-2005, 03:46 PM
BrodyP's Avatar
BrodyP BrodyP is offline
AF -Advisor
Is the physical light itself getting water inside of it or is your trunk ?
03.IS300.MT.LSD. 'Supra in Training'
Old 04-12-2005, 05:12 PM
Re: Re: tail light removal help
i dont have a leak yet, trying to remove tail light but cant get plastic studs off, and wondering is there any adivce on keeping leak out when i put the new tail light in
Old 04-13-2005, 03:03 PM
Shiftee97EX's Avatar
Shiftee97EX Shiftee97EX is offline
Send a message via Yahoo to Shiftee97EX
When I installed my red/clear lights, I used clear silicone to prevent any condensation. The lights should have come with a inner liner that is made of like a rubber type material. That will help to prevent any water from leaking into the trunk. If it did not come with those, they should be on the lights that you are taking off. You definatley want to silicone any aftermarket lights whether it be a head light or tail light because 9 out of 10 times they will build condensation when it rains or when you wash your car.
Old 04-14-2005, 07:05 AM
oh i see, yes it does have silicon on the new one, but i cant get the old ones off, there is a plastic stud preventing me from pulling it off, do i just rip the plastic stud off?
