Old 04-10-2005, 11:46 PM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
WHAT HARNESS SHOULD I USE?? B18 swap
Hello, i am putting a B18 LS out of a 94 integra into a 89 civic DX. If i use a SI wireharnes can i skip the whole MPFI swap?
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
Old 04-11-2005, 01:21 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: WHAT HARNESS SHOULD I USE?? B18 swap
no you cant put a si harness on your dx or i should say it would be easier just to convert your dx harness to mpfi than to change the si harness to work with the dx. also the 94 teg motor is obd1, are you going to switch to obd1 or stay obd0 ?
Team Lonely Drivers
Old 04-11-2005, 11:13 PM
i dont know which way would be easier OBD 0 or OBD 1 and how do you do either one? Thanks
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 04-12-2005, 04:11 AM
depends how good you are at wiring and the cost. i mena did the 94 ls motor come with a dist ? if you want to go obd1 you need a obd1 ecu, dist, and 4 wire o2 sensor, and a wiring harness adapter. if you want to go obd0, you need a obd0 dist, ecu. you dont need the o2 sensor for obd0
Team Lonely Drivers
Old 04-13-2005, 11:18 PM
yea i have the OBD1 ecu, dist, the wireharness that is attached to the engine, and all that. How do i convert it all to OBD1? I know i little bit about it but not much. can i cut the plugs off from the fire wall and the plugs of the harness on the engine and match them up or what? Let me know.
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 04-14-2005, 02:59 AM
no, you gotta modify your stock harness by doing the mpfi swap. then get a obd0-obd1 ecu conversion harness. the only thing you might need is a 4 wire o2 sensor. oh and when you do the mpfi swap you dont need a resistor box because saturated injectors dont use a resistor box
Team Lonely Drivers
Old 04-15-2005, 12:11 AM
damn it i just bought a resister box and injecter harness. So the 94 injecters dont need it for the MPFI swap? Thanks for all your help
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 04-15-2005, 01:33 AM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
No, OBD1 injectors dont need the resistor box...
