Old 04-11-2005, 12:32 AM
t rev t rev is offline
stiffer suspension
I've got an 87 Nissan 4x4 pickup, lookin to put a HD bumper and winch on it and wondering if anyone knows of a way to stiff up the front suspension to handle the extra weight. I broke a torsion bar wheelin the other day, so I'm putting in another set of torsion bars and then modifying them to get extra lift, but that doesn't stiffen it up. Any suggestions would be appreciated, thanks.
Old 04-11-2005, 02:08 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: stiffer suspension
With torsion bars, cranking them up is really all you can do. It does stiffen the ride, although not much. You may be able to find some full-size torsion bars that will fit your nissan.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-16-2005, 10:31 PM
v10_viper's Avatar
v10_viper v10_viper is offline
Send a message via MSN to v10_viper
I think that torsion bars do stiffen it up pretty good. I cranked mine up an inch and before I used to be able to push down on the front of the hood and make the truck go down, now If I push on it it barely moves, I can notice it in the ride too.
Wait a minute, you mean to say a bottle of pop is bigger than your engine??
"Pain is weakness leaving your body"
There is NO replacement, for displacement...
2007 Kawasaki ZX10-R S.E.
Old 04-27-2005, 06:45 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Yes, you can adjust the torsion bars to "stiffen" up the front of the vehicle...which is why it lifts it too.
