Old 04-10-2005, 08:01 PM
RobbW RobbW is offline
94 coolant replacement
I have a 94 GP SE, and a sticker under the hood says to see the owners manual for instructions for the coolant fill procedure or you might damage the engine. Well I want to drain and refill but don't have the manual. What's the secret process?
Old 04-14-2005, 08:54 PM
jchavis jchavis is offline
Simple. Pull the front end up on ramps / elivate the front anyway you can. Disconnect the lower radiator hose and let it drain. insert water hose and run water through till clear water comes out. You might want to use a chemical cleaner. Reconnect the lower hose and fill with the DexCool and your all good. make sure to follow the mixture on the back i.e. 50/50. Use distilled water only.
