Old 04-10-2005, 06:00 PM
shoobs99svt's Avatar
shoobs99svt shoobs99svt is offline
Send a message via AIM to shoobs99svt
Question Rotors: Drilled or Slotted
Im looking into swapping my current rotors (99 cobra) over to a more performance set up and different pads. Ive havent had enough experience with either, but so far ive heard good vs bad things about both cross drilled, slotted, and both. Crossdrilled ones can (will) crack and wont last as long, where slotted use up your pads real quick. Any truth to the chaos? Im looking into brembo 13s and 11.65s with upgraded ceramic pads, wanting both performance and endurance.
Old 04-11-2005, 11:23 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Rotors: Drilled or Slotted
I would not run drilled discs.
I do run floating sloted discs though. Basically the biggest rotor(disc) you can find, will stop better. Take material away, it decreases it ability to disipate the heat.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 04-12-2005, 04:53 PM
Mendari Mendari is offline
Originally Posted by shoobs99svt
...but so far ive heard good vs bad things about both cross drilled, slotted, and both. Crossdrilled ones can (will) crack and wont last as long,...
The problem with CrossDrilled vs. Sloted lies not with the machining process, but with the quality of metal used.
For example, a pistol made of billet steel will not explode in your hand as would a pistol made from cast iron.
In a nutshell, I've owned Stillen Cross Drilled Rotors and they have not cracked with more than 50,000 miles on them.
I have seen cheap PepBoys cross drilled and they are garbage.
Old 04-12-2005, 05:05 PM
SkylineUSA's Avatar
Re: Re: Rotors: Drilled or Slotted
This is true to a point.
Any drilling into a piece of metal will fatigue it.
And like I mentioned, holes in the rotor will decrease its ability to disipate heat, which is what actually stops the car
Old 04-12-2005, 09:27 PM
eillob's Avatar
eillob eillob is offline
Why does Porsche use them on the 911's?
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 04-13-2005, 12:29 AM
SkylineUSA's Avatar
Porsche does not drill their rotors, and they are very expensive.
Everyone brings up the fact that Porsche uses those types of rotors when this subject comes up.
Eillob, do the research and come and tell us why they use them.
Old 04-13-2005, 04:39 PM
What kind (brand) of slotted are worth the buck? Also, any brand preference for the pads?
Old 04-13-2005, 09:34 PM
eillob's Avatar
Ok Skyline here's what I found. The new 911 GT3 comes with Porsche patented crossdrilled rotors. Take a look http://www.germancarfans.com/news.cf...porsche/1.html
For the most part you are correct most Porsches don't come with cross drilled rotors but there are exceptions.
Heres some good info I found for this thread.
http://www.autoaccessorystore.com/re...kes/rotors.asp
Old 04-14-2005, 12:14 AM
SkylineUSA's Avatar
http://www.automotiveforums.com/vbul...ghlight=brakes
I spent some time on this one, read it.
Old 04-14-2005, 08:15 PM
eillob's Avatar
That, was a good thread.
Old 04-15-2005, 10:38 AM
SkylineUSA's Avatar
Like I said, I spent some time on that one.
It's funny when that one guy that was not agree with me, then realized what I was saying was right.
Old 04-16-2005, 11:41 AM
tturnpaw's Avatar
tturnpaw tturnpaw is offline
Send a message via AIM to tturnpaw Send a message via MSN to tturnpaw
I choose to side with Moppie on this one! Both of you make this easy to understand, and so far, Skyline, you have gotten me to pick up some oversized slotted rotors. Thanks a lot!
1982 Mustang GT- roller motor x303 cam, GT40s, MAC/Spintech exhaust MSD ignition, Edelbrock Carb, Ford Racing roller rockers
1994 Escort 2DR LX - cone air, 3.8L throttle body, FUTURE SPI turbo swap
Cops: You can race, but Im impossible to chase!
LS WHAT?
Old 04-16-2005, 01:34 PM
SkylineUSA's Avatar
Your welcome
