Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-10-2005, 11:33 AM
stoneage stoneage is offline
Question Talon goes Click-Click and Shuts off Abruptly? Plz help
Just can't seem to figure this out? I've been having this ongoing problem for a good part of more than 3 years and the main reason why I haven't sold it or drive it for the most part. Warm or Cold gas or no gas the car will just shut off, it goes click-click and shuts down. Once it lasted for about 4 months not doing it so I felt the problem had fixed itself but nope it came back. I've had the computer repaired by a reputable shop, fact its still under warranty, I really need help with this, if anyone may know what may be my problem. September last year I took the car over to Dodge to have it diagnosed, they came up dry, nada, funny thing is I had the car towed there because it would not want to stay running, it would run for a little bit then die, I get the car back from Dodge they say the car runs fine hasn't died out yet, they test drove it, let the car idle for awhile, I get it back drove it a few times to work since then with no problems. The other day I decided to degrease the engine bay, while I was in there I noticed why I wasn't getting a temp reading on my gauge for a while now, the wire fell off, I reconnect the wire, soon as I start the car it idles for a bit and abruptly shut down again. Now it can't stop doing it. The car runs well when it's running, but does act up when I get on the throttle and the car is running a little hot, I feel like I'm pulling 1000# behind of me....Plz help I'm desperate
Old 04-11-2005, 12:28 AM
No one have the slightest IDEA!
Old 04-11-2005, 11:24 AM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: Talon goes Click-Click and Shuts off Abruptly? Plz help
I dont know. maybe you need a new fuel pump and filter.
....It has been a LONG time...I want to move to FL or Japan.....
Old 04-14-2005, 07:16 PM
beatdown944 beatdown944 is offline
woiergf
uhh, talon??? there are like 3 different models. is it turbo? you might wanna check the crank position sensor if it is a turbo. if this sensor is all chewed up, you got problems.
88 e300, needs work.
95 gsx, stock, sticky icky tires. SOLD!
Old 04-15-2005, 12:05 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Where does the clicking sound come from?
Kris
2012 Genesis Coupe 2.0t
Old 04-15-2005, 02:23 PM
awbr awbr is offline
Send a message via AIM to awbr
maybe u have bad injectors,,, try to put and injector cleaner in it??? not to sure sorry man!
Old 04-15-2005, 02:31 PM
Look, axles click, ECU clicks, injectors click when they fire, lifters tick, etc.
Lets not provide a diagnosis until we identify the problem.
Kris
