| Off-Topic Talk about anything other than cars. |
hey, i just got my new EvoIII 16g installed yesterday
with the mods i have now (none???) i can't tell a huge difference between it and the t25 but hopefully by mid summer ill have the rest of my upgrades bought and installed, but im just stoked im finally getting to drive my car again. it's been down for almost two weeks. but the evo is quite badass, like i said, without supporting mods it's not a huge leap, but i can still tell a fairly nice difference. ony problem i had after me and my mechanic friend installed it was he cut the stock lower intercooler a little short so it wasn't on the j-pipe very well, so when me and another friend took off down an old deserted road to set my MBC, at about 11 p.s.i.... PPSSSSHHHHHH.... the lower intercooler pipe blew off but i got under the car and tightened it up as hard as i could and boosted a steady 14 p.s.i. all the way to 100mph (didnt take long at all ) but i just wanted to let out all my happiness about my new turbo and my girlfriend was getting sick of me talking about my car so i figured id come and do it here to people who might care.
95' Gs-t (broke the fuck down...) 68' Mustang getting reassembled right now, 82.763% done ![]() ![]() http://www.tagworld.com/milton666 |
Re: EvoIII 16g'ed
congrats! welcome back to the boost!
DSM geek |
Re: EvoIII 16g'ed
Good to hear!!! Now ya make me geek even more for my evoIII16g...with the supporting mods!!! lucky bastard!!!!
Of course most females hear bla bla bla when ya talk about this stuff... my wife just gets a look like a "like I care" look...lol
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan |
My gf knows more about turbocharging than most Honda guys
Glad you're 16g'd, just give me three months to catch up...
I used to own a DSM. Quote:
Re: EvoIII 16g'ed
I just put in a EVO III last week. Good turbo! Make sure you don't run 14psi on that stock turbo unless you have race gas. It will run, but not good for the car. You really need some supporting mods before you can start to open that thing up. Full exhaust, BOV, and if you are starting to raise the boost DEFINITLY a new fuel system.
Need a GOOD 6-bolt engine? Quote:
'95 Talon Tsi EVO III GT, supporting mods, not running Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped. |
Re: EvoIII 16g'ed
ive got it set at around 13-14 p.s.i. too much?
Re: EvoIII 16g'ed
what will it do to the car?
Re: EvoIII 16g'ed
Stock fuel system can easily do 14 psi on a 16g. 1g pump might be a little risky though, if its not rewired. Stock boost is 14 psi for a 2g. And the flow between the t25 and 16g isnt terribly different at that boost level. Over 15 it really starts to seperate though. On a cool day I couldnt go over 16 psi on the stock pump, with a supra SMIC. If you guys are logging airflow its even easier to tell if you are near the limits. Check my website for the excel spreadsheet that will give you the limit of the pumps in terms of airflow. Assuming pump gas with a spcific gravity of .76 and a target AFR of 11:1, the 1g pump is good to 31 lbs/min (about the MAX on a 14b) and a 2g pump is good to 40 lbs/min (about the max on a 16g). At 15 psi however, airflow is well below what the turbos max out at (~25 psi for 2 liter with stock cams/intake). Hope that makes some sense.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Re: EvoIII 16g'ed
Actually, I have some input as far as logs with DSMlink. I was actually just reviewing them. I got as far as 30lbs a min on mine, and only at 12 or so psi(creeped a little bit). My IDC was around 104%, so they were opened more then all of the time. No knock up there though at all. Plugs look fine. Make note that I have a 255, so that helps a bit. But regardless, an ECU doesn't know fuel pressure, so IDC is something to worry about. I am very conservative, so don't take this as a warning or anything. (I can't afford to screw anything up right now). Kevin said it best how at this boost level, they are way below what they are capable of. You should be ok, just watch for it creeping up, they love to do this.
Aaron B. 95 TSi DSMlink'ed Evo3'ed 6 bolt 52.7 1/4 second try 11.0 1/16th 2nd in league. 22.3 1/8th Ties league record. 6.6 55 meters |
Re: EvoIII 16g'ed
Stock fuel system will run poorly on a 16g...Knock will be a problem. The stock fuel system was made for a turbo that flows 290 cfm's versus the EVO III's 550. Almost a double in airflow there....The stock pump doesn't flow enough to run a 16g on 91 octane safely. It will run, but you can hit fuel cut pretty easy...Speaking form experiance here.
Stock boost is nowhere near 14psi for a 2g!!! The acuator on the t-25 is set around 10-11, with a possible 13 with the BCS mod. The flow difference is HUGE!! the stock t-25 will support like maybe 250 hp with a huge amount of supporting mods, which would have been better spent on a turbo upgrade. At 14psi, the t-25 actually starts to lose efficency and makes LESS power than at stock levels. The gases coming out of the t-25 will be very hot at these boost levels, and the "gains" are actually detrimental! The hot gas will expand and will actually take up more space than the air coming out of the turbo at ~11psi. You don't want to run your injectors at 104%, mums the word on 80% for most injectors. The 16g can chew enough gas to take FULL use of a 190LPH fuel pump, which is rated for 400 Hp, which is the max a EVO III flows. Even on the stock fuel system, your car will run, but much much much more performance can be gained by adding 550's+ and a fuel pump. This is what most people call a "minimum" fuel system to run the EVO III. Ideally, you would want some sort of fuel management, dsmlink or safc II. Even if you do manage to get by without any fuel cut, if you ran it for very long on the stock fuel system, you would start to get knock and detination. At 12psi you can see from the guy aboves data, that your fuel system is actually over working. Unless you are running some solid 94+ octane, I would HIGHLY reccomend you stay away from anything higher than 12psi on the stock system. However, you will want to get fuel pump and injectors asap! As it was mentioned earlier, the EVO is not very effective at 12psi. It really starts to make power around 16, which can be done with Fuel pump, injectors , and ideally a safc. I wouldent run 16psi for long without fuel tuning. With fuel system, and supporting mods....which you should already have, you can run a 16g at 18psi allll day long. Use better gas for anything above 20ish psi You will be able to run your turbo without these mods, but in the long.....err medium run really, you will notice your performance goin down the hill as you trash your engine. 16g will def creep, so get out that die grinder and go about 1-2 inches into the o2 housing. Works wonders. Honestly since you have no mods, it would be stupid to run 14 psi. You need to get some supporting mods asap. musts are exhaust, intake and a upgraded bov because the 2g one is a plastic peice of shit. 1g bov's hold 18psi and can be found for about 40 used. good part. Also, another problem with the EVO is going to be HEATSOAK. at 16psi, you will heatsoak very quickly, so plan on getting a upgraded intercooler (supra smic is good, front mount is usualyl better...either is waaayy better than a stock one) Never assume because you don't "feel" or "see" anything wrong with your car, that there isn't something goin on. You don't hear knock at all, which a lot of people are confused by, and ends up costing them an engine. Yes, its scary to think about, but would you rather have some shitty fun on a 16g for a month (until your car detonates it self to death) with no supporting mods, or hold off on raising the boost till you get what you need and can run 18 psi all day and begin the mass rapeage of camaros and such. It's a lot to take in at once, but it takes less time to get all this shit together than you think. EVO III has taken peeps into the 11's. 2004 corvette zo6 = mid 12's
Re: EvoIII 16g'ed
Whathits14, your mod list says EvoIII GT. Is that the Chinese knockoff one? If it is, how's it holding up so far?
![]() '99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed) Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/ Adopt pets in need! http://www.petfinder.com/
Re: EvoIII 16g'ed
i hate the chinese
Re: Re: EvoIII 16g'ed
Re: EvoIII 16g'ed
My boost is 15-16 so I'm guessing from what your saying that I should be getting a boost controller. I haven't taken out the BCS or anthing like that so why is my boost so high?
Re: EvoIII 16g'ed
my gauge is reading about 13-14 p.s.i. but im gonna back it off a little bit to about 12 after reading what everyone said, and yea my next few mods will be intake injectors fuel pump and 1g blow off valve, but i gotta save some $$$ first, the new turbo broke me, but like i said in my other thread, dont yell at me for making a new turbo one of my first upgrades. my t25 went out and i knew id get an evoIII eventually so i figured why not now? but thanks for all the info and advice
