89 Probe 2.2 motor
is this an interference motor?
Re: 89 Probe 2.2 motor
interference?
93 FORD PROBE GT JDM manifold ported match 65mm TB Unorthodox Underdrive Pulley Hotshot headers 3' Exhaust all the way No cat Cold air intake K&N air filter Short throw shifter Eibach lowering springs FX Design Body Kit B&M Short Shifter Stage 3 Clutch MX-3 Flywheel Performace Wires and Plugs Synthetics Performance Rad and fan Mild Weight Reduction Coming this week: Performance Heads and Cams 3 angle head job Why does everyone have to piss on Ford.
as in if the timing belt snaps, will the piston collide with the valves and bend them?
if your timing belt snaps, your engine will just shut off, it shouln't do anything to the actual engine. THe belt just make sure its all lined up if it breaks you'd probably want a pro to do a retiming just incase.
