Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 04-10-2005, 09:00 AM
SyK SyK is offline
Eclipse Problems
I have a used 2000 mitsubishi eclipse and its a little beat down but i am willing to fix. It is making a strange noise when im making left turns and the tighter i turn the louder it is. What can this be?
Old 04-10-2005, 11:18 AM
2002EclipseRS's Avatar
2002EclipseRS 2002EclipseRS is offline
Re: Eclipse Problems
Does it have Aftermarket Rims/tires? If so, it sounds like your tires are too big and are rubbing on your wheel well
Made the switch from Mitsubishi -> Honda (acura)....so glad i did!
Old 04-10-2005, 12:11 PM
SyK SyK is offline
Nope they are original i believe, 18 inch i think the guy was telling me. Anyways i dont know crap about cars i think im probably going to have to take it to a mechanic and let him rob me for my money. Got any other ideas of what it might be, its hard to describe the sound the only thing i can think of is it is not a steady sound. Any ideas would be very helpful.
Old 04-10-2005, 01:17 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
the original wheels are not 18's. so either you have 18's or the guy lied to you and told you they were 18's. the best way to find out is to go outside, look at your tires, and get the numbers off the side. they will be in a format similar to this.... 225/40/18. post that number in this thread and we will let you know if its the tires rubbing.
also, is the car lowered?
Old 04-10-2005, 02:04 PM
SyK SyK is offline
Hmm the wheels i just read them they say "16.5 ince rims" I cant find the 225/40/18 format however. I think the car is pretty much all stock but i could be wrong, how many inches should the car be off the ground.
Old 04-10-2005, 03:26 PM
evil6remlin evil6remlin is offline
the stock front bumper height is around 4 inches from the ground
Old 04-10-2005, 04:22 PM
the 225/40/18 is on the TIRES not the RIMS.
and ive never seen 16.5 inch rims.
Old 04-10-2005, 07:24 PM
Tyrone Biggums Tyrone Biggums is offline
first, tell us what the tires say. should be something like- 205/50/16. i belive thats the stock size. if that matches up, then you might have a problem with your power steering, or some other drive train part.
www.Club3gse.com
Old 04-10-2005, 08:02 PM
Back's Avatar
Back Back is offline
Banned
Im thinking the power steering. When was the last time everything was greased underneath?
Old 04-10-2005, 08:15 PM
yeah because he says it gets worse the tighter he turns.....he needs to describe the sound better.
www.Club3gse.com
Old 04-10-2005, 09:21 PM
Black Knight 00's Avatar
Black Knight 00 Black Knight 00 is offline
Send a message via AIM to Black Knight 00
couldnt it just be a bad tie rod?
Old 04-10-2005, 10:38 PM
i would check the tire size first, then the power steering fluid, then the tie rod/wheel bearing/other suspension related parts
Old 04-11-2005, 06:39 AM
SyK SyK is offline
Im pretty sure its not power steering becuase it doesnt effect the steering. On my old car the power steering was leaking and it got tight in the wheel and the power steering fluid is full. I found the format you were talking about and it says P205/55 R16 .
Old 04-11-2005, 07:26 AM
ok so its not the tires and its not the power steering fluid. you will probably need to get the tie rods or wheel bearings checked.
Old 04-11-2005, 07:42 AM
SyK SyK is offline
Hmm does that usually cost alot? Thanks for the help btw , you have been very helpful.
