Old 04-10-2005, 06:26 AM
David John David John is offline
Transmission fluid level
This might be a stupid question but is being a little low on tranny fluid really bad for your transmission? I mean it wouldnt effect anything would it? I should just add more right? Thanks for helping out...Its only my first truck. It shifts fine if your wondering...but thanks for any information
Old 04-10-2005, 07:23 AM
16th hippy 16th hippy is offline
when you check it, if there is no fluid onthe stick, you should add half a quart, and check it again. keep doign this until it is in the safe operating range as indicated on the stick.too much is bad, and way too little can burn it up. not a stupid question if you don't know the answer..is always best to ask if you don't. if you have anymore questions, just ask, that's why we're here.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 04-11-2005, 04:15 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Transmission fluid level
You checked the fluid level with is running hot right?
Also, go through all the gears slowly all the way to 1 and back up pausing for 5 seconds each time to get the right level.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 04-11-2005, 05:03 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
^ or, you could check it while its ideling in nutral, like most of us
Old 04-11-2005, 06:16 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Transmission fluid level
Actually, you check it in hot idle in park after cycling through all the gears to make sure all the solenoids are filled so that you get the proper level.
