Old 04-10-2005, 01:25 AM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Kenwood amps
I just bought a new kenwood amp yesterday(KAC-9152D)
it took a huge chunk out of my wallet (500) but i'm hopin its worth it.
I'm powering 2 MTX 6000 15's I obviously have the power to due this but i just want to know how good these amps are and if there anything i whould watch out for this.
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
Old 04-10-2005, 03:01 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Kenwood amps
are you sure that model number is right?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 04-10-2005, 05:07 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
I absolutely LOVE these posts ....... don't you think you should ask about whether something is any good or not BEFORE you buy it ?
Old 04-10-2005, 05:16 PM
Diceman83's Avatar
Diceman83 Diceman83 is offline
Send a message via AIM to Diceman83
Re: Kenwood amps
heh... I know I should have. Of course, my entire collection of sound upgrade stuff didn't even cost as much as that amp.
Old 04-11-2005, 12:17 AM
Re: Kenwood amps
the reason is b/c i got the amp, but i haven't been using mono amps before and for some reason i cant get it to turn on. I dont know if you have to change the wiring or it has to be running at 2ohms to work.
93 FORD PROBE GT
65mm TB
Hotshot headers
No cat
Cold air intake
K&N air filter
Short throw shifter
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Synthetics
Coming this week:
3 angle head job
Old 04-11-2005, 07:03 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Re: Kenwood amps
Nope, they're no different than any other amp really. Take a look at the speaker terminals to make sure that they are actually what you think they are. Sometimes they are setup a little different than regular amps. Also, make sure you have the proper power, ground, and turn on.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 04-11-2005, 07:21 PM
Re: Kenwood amps
i took it to a pro at A&B sound (were i got it) and found out it was just a faulty amp, after I hooked up the new one, my 15's are pounding like crazy. The amp just came out in stores this week, it says 900rms at 2ohms on it but i did a power check on it and it puts out 590rms@2ohms which is great b/c my 2 subs r 300rms@4ohms.
FOR THE NEWBIES
Anyone who wants to know how to do an actual power check or the most your amp actually puts out (you can also do this at the store to see how badly you r actually geting ripped) take the total of your fuses EX. 60 and times it by 14.4 to get the MAX watts then times that number and times it by .7 to get the rms. That number will be around the actual rms due to you dont always get 14.4V of POWER.
93 FORD PROBE GT
65mm TB
Hotshot headers
No cat
Cold air intake
K&N air filter
Short throw shifter
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Synthetics
Coming this week:
3 angle head job
Old 04-11-2005, 09:45 PM
sr20de4evr's Avatar
FOR THE NEWBIES
That will get you within maybe +/- 50% of the actual power output, that's about it. And you don't need to multiply by .7, that's to convert an AC voltage/current in the form of a sine wave into an rms voltage/current, the power coming from your battery isn't AC and it's not in the form of a sine wave. It's DC, so technically it's already "rms".
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-12-2005, 10:52 AM
notladstyle@yahoo. notladstyle@yahoo. is offline
Send a message via AIM to notladstyle@yahoo. Send a message via Yahoo to notladstyle@yahoo.
Re: Re: Re: Kenwood amps
you cant measure RMS without knowing the true draw from your amps, your fuses are ridiculous benchmarks as they are only there to prevent fire. You also cannot measure against 14.4 volts because when any substantial load is placed on the electrical system most regulators will drop to and maintain 12.5 to minimize stress on the alternator.
To get a decently accurate measurement without any measuring equipment, take an ohms/ampre meter and measure the current draw while running a test tone(below 100hz for subs) and use 12.5 volts. If you have yellow/redtop or a real cap (1f @ 20v +/-10%) then you might get away with 13-14v then take 60-70% of that value to compensate for innefficiency.
You can easily find a subwoofer test tone on any p2p
*** CHEAP OHMS METERS WILL ONLY MEASURE 10-15 AMPS BEFORE CATCHING ON FIRE ***
... so ensure your ohms meter can channel the current. or get an amp meter
() I claim no responsibility for your death
Neon Lights add 10hp... per color
It seems my sig pic was too big for some ppl to see on their screens - srry about that
Old 04-12-2005, 11:29 AM
sr20de4evr's Avatar
Re: Kenwood amps
Or just measure the voltage and current leaving the amp and don't worry about efficiency....and you think a capacitor would do anything for you on a test tone? haha, on a test tone it'd be even worse than not having one at all.
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-12-2005, 01:39 PM
The current leaving the amp requires a real meter... I was giving a method using only an amp meter. and no a cap wouldnt help with a test tone but it might help with scaling...
Old 04-12-2005, 02:22 PM
Re: Kenwood amps
They way I was taught is what they teach you in an audio school in alberta, if you want to work in any high electronics store, or big in the industy in canada you have to go there. (simply the best).
Any you have to take you voltage in and your fuses to measure the output b/c your amp may say 1000rms but you fuses only with allow 500rms. That's why the pro's look at the fuses output first.
93 FORD PROBE GT
65mm TB
Hotshot headers
No cat
Cold air intake
K&N air filter
Short throw shifter
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Synthetics
Coming this week:
3 angle head job
Old 04-12-2005, 02:57 PM
sr20de4evr's Avatar
a real meter like what?
My cheap little DMM can read up to 10 amps rms of AC current, with a 4ohm sub that's enough to measure 400rms of power, provided you had another one or a scope to measure the voltage across the terminals. More than 10 amps and you would need a clamp-type ammeter, but the same goes for measuring the power going into the amp, except if you're measuring the input side you would need a clamp-type ammeter for any more than ~80rms instead of 400rms.
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-12-2005, 03:03 PM
sr20de4evr's Avatar
The problem is, those fuses are slow blow. You can draw double their rating for quite some time before they'll let go, they're only there to cut the power in case of a huge surge. If you go by the fuse rating you're only going to get somewhere in the neighborhood of the right answer. Not every amp has a fuse anyway, out of the 3 amps in my car right now only one of them has a built in fuse, and it happens to be the smallest and cheapest of the 3.
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-12-2005, 06:21 PM
Re: Kenwood amps
Fuses=RMS that's gotta be one of the funniest things I have heard. As anyone knows, the RMS output is totally dependent on the power input just like stated above.
Back in the early days we use to use a stepup voltage regulator like what's used on Nascar. Well, you could set them up so they'd regulate a true 14v or even 15.5v. It's how pros would cheat in competitions. Most amps were rated at 12volts so you could easily double many amps' outputs by going to 15v..
Pioneer 4900mp
Orion C63 Coax rear
