Old 04-10-2005, 01:05 AM
rsiewert's Avatar
rsiewert rsiewert is offline
Send a message via AIM to rsiewert Send a message via Yahoo to rsiewert
Question Degreased 4.0, now tranny not engaging past 2nd
Here's an odd one. I cleaned my '89's 4.0 today (degreaser and water wash) trying to avoid wetting the distributor cap etc. After finishing I went to drive and now my auto transmission won't upshift past 2nd. Reverse is fine.
Did I soak a vacuum hose? Did I get an electrical connection wet? This one stumps me as I have never had an issue with the tranny previously.
Any ideas welcomed! Thanks all!
Ron
1989 Cherokee Laredo
Old 04-10-2005, 02:34 AM
tblack tblack is offline
Re: Degreased 4.0, now tranny not engaging past 2nd
This is a tough one. Did you power wash it with a high pressure? The thing that comes to mind is a sensor either got wet or got its connection knocked loose. You may just need to spend some time inspecting all around the engine and transmission to see what got knocked loose.
tb
Old 04-10-2005, 10:29 AM
xj31 xj31 is offline
you might have got the tps wet.
Old 04-10-2005, 06:03 PM
Re: Re: Degreased 4.0, now tranny not engaging past 2nd
Originally Posted by Dale Aeppli
SOUNDS LIKE YOU MAY HAVE TROUBLE WITH THE - TPS-- SENSOR THEY ARE VERRY TOUCHY TO HEAT AND MOISTURE. SOMETIMES YOU CAN USE A BLOW DRYER TO DRY OUT THE CONNECTION ON THE SENSOR. WE'VE DRYED THEM OUT USEING AIR. HOPE THIS IS OF HELP DALE [email protected]
Is there an echo in here?
Old 04-15-2005, 10:08 AM
rsiewert's Avatar
Update: Looking for new/used TPS now...
Thanks to the two of you for your help... it would seem as if it is the TPS. I took it off and used a hair dryer on it but to no avail so I am looking for a used one locally or on eBay. I would have never thought of the throttle sensor as being a potential culprit so I really appreciate the help!
Of all the times I have cleaned the engine I have never run into this before... of all the mud and water I have taken the Jeep through it is ironic that it would go belly up from cleaning the rig... I'll watch that bugger from now on.
Thanks again...
________________________________
Ron Siewert - Spokane, WA
1958 Chevy Apache P/up
1997 Jeep Cherokee Sport
1997 Ford Expedition Eddie Bauer
2004 Ford Taurus SE
