I installed it to my TrailBlazer and work super. Beeps when it detects objects as far as 5 feet away. Only issue is whe I open the locks with the reverse lights go on in my garage and the the sensors start beeping since my garage door is about 6 inches away from my rear bumper.
Does someone knows how to bypass the remote control option of the rear lights on. We're I can connect the positive wire without using the reverse light Harness? Thanks Agustin [email protected] |
Re: Has anyone installed Back up Sensors on a Trialblazer 2004?
Yes, it depends on the system. The ones I sell have 3 wires on them. One for ground, one for 12v ignition, and one for light wire trigger.
Since you have probably only a 2 wire system, the easiest thing would be to use a relay. You can use it for the ground. Use an ignition wire as the trigger for the relay. So, when the relay "clicks" the system will then see a ground and turn on.
Silverado Ext. Cab 4x4 z71 Pioneer 4900mp Orion P6.2 Componet sets front Orion C63 Coax rear DirectedVideo 9" all in one DVD with surround 2007 SATURN OUTLOOK AWD XR with full entertainment package |
Re: Re: Has anyone installed Back up Sensors on a Trialblazer 2004?
Thanks for the info. Lets see how Ic can I measure it out. agustincorrea (Augie) |
