Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 04-09-2005, 08:22 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
1969 351c TT Mustang header build
Thought you guys might be interested in this. This is what I've been doing lately:
The material is black mild steel schedule 40 pipe.
Motor is a 351 Cleveland, thoroughly ported 2v open chamber heads, Comp magnum roller rockers, stock CJ cam(112 lobe sep, ~.520 lift). Blow thru 4779 750 holley DP carb on a Weiand Xcellerator intake manifold. Block filled to within around 1.5" of the deck with embeco cement. Forged JE blower pistons, 351w H-beam rods, stock crank, windage tray; around 8.5:1 compression. . Serpentine belt setup for the alternator(the only engine driven accessory). Electric Meziere water pump:
Aeromotive A1000 fuel pump, Aeromotive 1:1 regulator.
The power is being put through a Dynamic Racing Trans C4, reverse manual valve body, then to a 9" with a 31 spline locker with 3.55 gears.
Goal is 550rwhp for now.
Car is a 1969 Mustang Coupe. Originally a 302 car. Target weight is 3000lbs dry. Wheels will be 17" Black Bullitt replicas:
Tires will be M&H Racemaster 275/50R17 Drag radials:
For the strip I'll have a set of 28" drag slicks.
Expecting 11s, hoping for 10s!
Old 04-10-2005, 04:45 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: 1969 351c TT Mustang header build
That is frickin bad ass!
I am going the easier route, so I just bought a complete T76 kit for my 69 block for $3000.
You should hit 10 easy, as long as you can get the traction.
What turbos will you be using?
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 04-10-2005, 05:21 AM
duplox's Avatar
I'm going to break the motor in N/A, put at least a couple hundred miles on it first. Then I have two choices.
I already have a pair of T3 Super 60s, .60/.63, that would probably work decent. However, I don't think they can provide enough flow to feed it above 5000rpm or so, and they'll spool damn fast. Probably as close to instantaneous without being severely undersized. They'll probably be good enough for 525ish bhp, but I know plenty of guys pushing this on stroker N/A clevelands who have a lot less money in their motors.. I've obviously got to beat them, right?
So my other option is to buy a pair of t4s. The trick is to find some with the right A/R exhaust turbine, the vast majority seem to be 1.15+. I just found some on ebay with .96 housings, but I'd like to see if I can get a couple with the .84s. These would certainly have the flow for my motor, and definately a bit of headroom to get more power out of it later on.
Old 04-10-2005, 07:42 AM
SkylineUSA's Avatar
I'd go .84s myself. .60/.63 are pretty small, and of course your right about spool for them.
