Old 04-09-2005, 07:30 PM
germanyt germanyt is offline
can you do this?
ive been looking at diagrams and i dont think you can do this but i figured id ask. can you wire two 4 ohm single voice coil subs into a single 4 ohm load
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
Old 04-09-2005, 07:47 PM
Diceman83's Avatar
Diceman83 Diceman83 is offline
Send a message via AIM to Diceman83
Re: can you do this?
Nope. 2 ohms in parallel or 8 Ohms in series are the only combos of 2 4 Ohm subs.
Old 04-09-2005, 09:26 PM
that is what i thought but i figured id ask anyway. thanks
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
Old 04-09-2005, 09:36 PM
notladstyle@yahoo. notladstyle@yahoo. is offline
Send a message via AIM to notladstyle@yahoo. Send a message via Yahoo to notladstyle@yahoo.
it is possible however I dont know whether it would provide the performance you are looking for. you would need to produce a VERY high voltage coil with a 2ohm impedance. Wire it in series with the two subs in parallel and you will theoreticly have your 4ohm load to the amp.
you will not get any additional power over using the dual channels on your amp as opposed to the single channels.
Neon Lights add 10hp... per color
It seems my sig pic was too big for some ppl to see on their screens - srry about that
Old 04-09-2005, 09:58 PM
Diceman83's Avatar
that's not what he was asking... he has 2 single coil 4 ohm subs. Not 4. Yes you could have two sets of two subs in parallel to make a 4 ohm load to the amp, but that's not what he asked.
Old 04-09-2005, 10:01 PM
Re: Re: can you do this?
read closely, i said a COIL with a 2ohm load - you can buy one at radio shack.
take the TWO 4ohm subs, wire them parallel to 2ohm, take the 2ohm COIL and put it in series. Then you have a 4 ohm load... its called impedance matching, home audio speakers use it often. I doubt if it will offer high enough power handling for automotive aplication though.
Old 04-09-2005, 10:09 PM
Diceman83's Avatar
Oh ok, your wording was confusing me I guess...
"you would need to produce a VERY high voltage coil"?
How do you "produce" a high voltage coil? Yeah, that would work, but going to 8 Ohms, while less efficient, is probably the safer route.
Old 04-09-2005, 10:14 PM
Radio Shack orders it for you.
really really think copper wiring wound about 1000 times should be close to 2ohms the problem would be not inducting the signal while maintaining the resistance. as the coil heated up its resistance would drop and your amp would fry or the coil would distort the output signal making the bass very dirty.
Old 04-14-2005, 11:52 AM
worm1869 worm1869 is offline
I got a rockford fosgate 300s and two 12" audiobahn subs that are dual voice coil. I was woundering how to wire these so i can get the most out of my amp and subs
Old 04-14-2005, 01:32 PM
worm, refer to the post GETTING THE MOST OUT OF DUAL VOICE COIL SUBS
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
