Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-09-2005, 08:17 PM
datpimp1 datpimp1 is offline
coolant leak
i have 1996 cutlass supreme every once in a while i notice a small puddle of antifreeze on the ground around the passenger front side , and when i get out of the car i usually smell coolant not a strong smell but i do smell it anyway i cahnged water pump a few months ago . and now that i think about it im not 100 percent sure i think the puddles only are there after i have had the heat on and i come back later on and notice the puddle i have good heat and everything , does the heater core only leak when u have on the heat? how hard is it to change ? is their any way to know if its bad without getting to it i understand that it is under the dash any help ?
Old 04-10-2005, 08:01 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: coolant leak
Check your hose connections, when a heater core lets go, it'll leak inside the car on the passenger side floorboard.
Old 04-11-2005, 04:38 PM
are u saying check the hose at the heater core? also the puddle is on the passenger side in the front not right by the passenger seat i dont know if that matters thoughi was thinking water pump because its close to the water pump but not directly under it but i just changed the water pump a few months ago so i wanna make sure of what it is
Old 04-12-2005, 12:46 AM
AF - Advisor
Re: coolant leak
What I'm saying is if coolant is leaking inside the car, your heater core is bad and needs replacing.
You're going to need a manual to learn how to correctly replace it too.
Old 04-12-2005, 08:19 AM
theragtopguy theragtopguy is offline
On the Cutlass, if the heater core is leaking, it will appear right where you say. Instead of going thru all the BS of rplacing the core, use some K&W Block Seal, it will fix that leak right up. Permanent fix, assuming it's not a hose. Do not mix with Antifreeze, follow directions thoroughly.
Old 04-13-2005, 01:01 AM
ok i understand what your both saying right now i cant feel any coolant leak in the car . lik i said it doesnt leak all the time sometimes i will check under the car and no puddle is their so i decided to let the heat run let it get to operating temperature but it still would not leak while i was checking , checked the next day still no leak so i guess i will have to wait until the leak is more noticaable does anyone know it the heater core just leaks afer you have on the heat ? or is is possible to leak at anytime
Old 04-13-2005, 02:56 AM
AF - Advisor
Re: coolant leak
If it leaks, it'll leak anytime, even if the motor is off or on and if the heater is off or on. It's part of your car's cooling system. If the cooling system has antifreeze in it, antifreeze can leak out the heater core if the heater core has a hole in it. Another sign of a leaky heater core is your windshield will fog up if it's cold outside and you turn your heater to defrost like your trying to clear your foggy windshield.
Old 04-13-2005, 11:19 AM
cableguy4k cableguy4k is offline
Re: coolant leak
There might be another possibility. The puddle could be from radiator overflow. Is the puddle in front of your tire? Is your radiator overflow bottle full?
Old 04-13-2005, 04:39 PM
the puddle is almost under water pump not in front of tire but a about 4 inches away my over flow tank is at the specified area unless
i was thinking about doing a pressure test on the radiator but that really wouldn't tell me anything
Old 04-13-2005, 04:49 PM
cdru's Avatar
cdru cdru is offline
To track down the leak, you might consider getting some UV dye from napa. You add it to the coolant, run it and then shine a blacklight on it. It will glow where coolant has been. This might help you figure out if its a leak (running down the block) or an overflow (running down the overflow resevoir), leaky hose (glowing hose) or a bad seal at a clamp (glowing connector).
You'll need to use a real blacklight or a florescent black light. Those $3.99 incadescent lights dipped in a blue coating won't work.
Old 04-13-2005, 05:21 PM
AF - Advisor
Re: coolant leak
First you say the leak is inside the car, now it's outside the car? Later dude..........
Old 04-13-2005, 06:51 PM
i will probaly just get some dye and sir im sure if u would read carefully i never said the leak was in the car thanks anyway
Old 04-14-2005, 10:54 AM
Re: coolant leak
Quite possible that the water pump is leaking. There's a weep hole in it, it will probably only leak when running.
Leaks are a pain in the ass to find sometimes.
Old 04-15-2005, 03:32 PM
thanks
