help
i no that this is a big problem with probes, mine doesnt have half of the power that it should. i thought that it might b the injuectors so i cleaned them, i did a tune up and now im out of ideas. please help i miss being thrown in2 my seat when i step on it
Re: help
hmmmmmmm. Well the only thing that i can think of that is maybe you throttle body might be need to be cleaned, or you need a new head gasket.
Or maybe, do u have any heating problems, if so it might cause the entire engine not to work properly. If you have the auto, u might have a problem were it doen't shift properly thanks to the bad auto ford put into the probes.
93 FORD PROBE GT JDM manifold ported match 65mm TB Unorthodox Underdrive Pulley Hotshot headers 3' Exhaust all the way No cat Cold air intake K&N air filter Short throw shifter Eibach lowering springs FX Design Body Kit B&M Short Shifter Stage 3 Clutch MX-3 Flywheel Performace Wires and Plugs Synthetics Performance Rad and fan Mild Weight Reduction Coming this week: Performance Heads and Cams 3 angle head job Why does everyone have to piss on Ford.
Re: help
i just cleaned my throttle body like 2 or 3 weeks ago and it is a stick. but no im not over heating im stuck ant other ideas?
Re: help
the only thing i can think of that isn't internally is that maybe you have a hole somewere in your exhaust, see if you can find a hole down your exhaust. OR your throttle cable might just have to be tightened.
i think that i found out wat the problem was. the engine actually blew. i was driving then i hella smelled gas and then i stoped and i fireball shot out of where the hood and bumper come 2gether and then me and my friends got out and it blew up 4 more times i think that might have been y it didnt have any power. thanks 4 the help anyways
Re: help
ouch that's gotta sux it guess it's time for the KLZE now.
that it wat i was thinking while i was watching the fire dept put it out. then when i got 2 c all of the damage the entire front of the car from the back of the fenders 2 the front is all melted and far past being fixed so im just gonna sign it over 2 the impound lot : (
