Put a diaper on it
The last time I had a significant oil leak fixed it took me six times back and forth to the dealer before they found the leak. That was back in '98 and my '94 Cherokee was four years old. Now my 2000 is starting to develop an oil leak and I do not want the hit and miss method of finding it. I will ask them to use die in the oil to find the leak, but am strongly considering having them change every oil gasket on it including the main seal so I will only need to make one trip. How many gaskets are on the 4.0L engine? Knowing this will help me decide if I want to do a complete gasket replacement, or just put a diaper on the engine if they send it back to me still leaking the first try.
tb |
oil pan, head, valve cover, main seal x 2 , distributer o-ring (if not coil packs) oil filter housing, seals on CCV x 2, am I missing any
Re: Put a diaper on it
Thanks for the info. tb |
Head, pan, valve cover, timing chain cover, oil sending unit, main sealsx2. Gues you guys only forgot the timing chain cover gasket
1995 Jeep Wrangler 3 1/2" lift 33x12.50 tires 4.5L stroked I-6 Bored throttle body & Cold Air Intake Jet Chip Stage 2 Jet Thermostat Colorado Off Road Rig!!! |
1000.00 and the headgasket not replaced, seems a little $$$ to me
