Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 04-09-2005, 03:50 PM
tarabull's Avatar
tarabull tarabull is offline
Send a message via AIM to tarabull Send a message via Yahoo to tarabull
Guess what I did!!!!
New front rotors and pads... only one broken nail, and a small scratch on my hand.... I'm soooooo excited, you know the haynes manual doesnt say anthing about having to use a hammer and pry bar to get the rotor off the spindle.....
hahahahahahaha...
I told the little girls riding by on bikes never to let anyone tell them they couldnt do anything.....
Old 04-09-2005, 03:55 PM
ExTrEmEDrIfT's Avatar
ExTrEmEDrIfT ExTrEmEDrIfT is offline
Send a message via AIM to ExTrEmEDrIfT Send a message via MSN to ExTrEmEDrIfT Send a message via Yahoo to ExTrEmEDrIfT
Re: Guess what I did!!!!
hmm it musta been on tere for a while if you had to use a prybar well sounds good glad it went well
Past Z Car Crew
[The Enemy Of Your Enemy is Your Friend]
>>Keep Your Friends close : But Keep Your Enemies Even Closer <<
Old 04-09-2005, 04:07 PM
tarabull's Avatar
its an 18 yr old car.... this I'm sure is the first brake job it's gotten...
Old 04-09-2005, 06:37 PM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
Well if they had been on there for 18 years the pads probably would have been ground away completely and you would have ground away the rotors by now.
But anyway, good for you. A woman that changes her own brakes, that just sounds sexy.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 04-10-2005, 01:25 AM
nissan_240sx nissan_240sx is offline
nice job
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 04-10-2005, 04:21 PM
Hodo Hodo is offline
Heres a tip for next time. Hit the rotors around the wheel studs...... becareful not to hit the wheel studs, it will losen them up from the hubs. Then when you put the new ones on you should sand down the wheel hubs to get all the rust and debri away from the new rotors otherwise they may sit awkardly and cause a brake vibration or warp the new rotors. Lastly make sure you clean the rotors with soap and water, then rough up the pads a bit before you throw them on. It helps the pads seat better. OH and put some brake grease, or perferably anti-sieze compound grease behind the rotor, between the rotor and the hub. You dont have to use alot just use a small paint brush and paint the grease on the hub between the studs, this will help the next time you do your brakes, they wont "stick" to the hub.
And congrats. Now you have to flush and bleed your brakes. But thats a leason for another day, baby steps first.
Finaly got pics of my car....... after I washed it of course.
Old 04-10-2005, 07:57 PM
tarabull's Avatar
well, i plan on doing the rear wheels next weekend... I will take those suggestions to heart!! thanks for the idears!!!
Old 04-10-2005, 10:00 PM
yah whenever i do a job like that i use my trusty rubber mallet and beat the hell out of it around the sides ... breaks it loose better
Past Z Car Crew
Old 04-10-2005, 10:08 PM
stephenp stephenp is offline
Send a message via AIM to stephenp
sawzall lol just pikin but if replaceing with new you dont need to use a rubber lol and good catch to the antiseize on the back side trick and i found in my case (area specific maybe??) but i found it to be cheaper to actually buy bendix instead of the oe
higher quality lower price????
(quote replaces oe, not that its bettert but it is a trusted name and i saved 15 a peice on them oh i almost forgot did i get scammed at 60 a peice???
oh well its done now
