Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-09-2005, 03:42 PM
cpophoto cpophoto is offline
Unhappy 1995.5 rodeo won't start?
I have a 1995.5 rodeo. My wife left it at the station ,it was fine. came home it would not start. there are no blown fuses, car turns over but will not start. It seems that it is not getting fule. Checked fule filter seems clear, pushed on fule valve in engin compartment and nothing came out. Is fule pump bad???? What should I do? Please help....
Old 04-09-2005, 11:21 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 1995.5 rodeo won't start?
It could be a bad fuel pump relay. I think it is under the hood. There should be another relay in the same box that you can swap around as a test.
If that doesn't work you can drop the fuel tank and clean the connections and see if that fixes it.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 04-10-2005, 08:54 AM
Already swaped the relay, that didn't work. Also the blower for the fan will not turn on when the key is in the on position, is that a sign of a major elec failure? All the lights and everything else works. Will try to test back to the tank and see if I'm getting power to the pump, thanks.
Old 04-13-2005, 02:57 PM
93 Rodeo 93 Rodeo is offline
Please post any findings as I have a 93 Rodeo with a 3.2 and have the same issues, have been swapping parts and tracking wires with no success.
