| View Poll Results: death wobel | |||
| shimmy |
0 | 0% |
| woble |
2 | 100.00% |
| Multiple Choice Poll. Voters: 2. You may not vote on this poll | |||
death woble
Have 88 larado. Front end has been alined. Tires have scalups. Started 2 days ago , speeds of 45 to 60 hole front end seems to go crazy. Have been back to good year for check. Every thing is tight. 157000 miles , stock system. Said to go to off road ware house ro find the problem. All ready costing two much. What should I check?
Re: death woble
Did the problem start before or after you went to Goodyear. I went to Goodyear for a simple wheel balance and tire rotation for my 2000 Cherokee and experienced some of that. I say take it to a REAL alignment shop and see what they say. Who told you to go to Off Road Warehouse? Off Road Warehouse? Is your front end modified? All you are going to find out at Goodyear shops is what Goodyear tires you should buy! tb |
Scallops on the tires are usually a sign of worn shocks, Goodyear should have told you that, caused by the wheel "hopping" because the shocks basically aren't keeping the tires on the ground. As for the alignment, I use an alignment shop in SD over near midway and rosecrans, it's all they do. Look for a shop that just does alignments, especially one that knows about 4x4 and solid axle aligns. ORW is a nice place to go shopping if you want to spend an exorbitant amount of money to build a pretty, chrome, sky-high 4x4 with huge tires that will only see dirt if you make a wrong turn and end up in an alley. There's better, smaller shops around SD who won't try to sell you a 90" lift kit and 78" tires. If all else fails, drive through the wobble and don't slow down 'til you see the blue grass of Kentucky :-) drive safe
Re: death woble
Thanks grey 88. I was told of that shop down on Rosecrans. Scallops acured because of going to long with out alignment.UR right about ORW. Only called to get some info.Shocks are good, bushings are original, but tight.If what ur saying after taking it into check it out, tires would be alot less costly,rather then dumping $$$$$ into a guessing game. Thanks for the imput. Do u know the name of that store?
Re: death woble
Mark's Garage est. 1983 |
Re: Re: Re: death woble
Re: Re: Re: Re: death woble
Mounted , balanced front, aligned front end the old way. Took it out, came back switch tire sides to make sure they were true. Done. Cost $333.41 parts an labor. Major parts Tires. All I can say is you don't mind spending the $$$$ for some one who does what they say they can do. True service today is getting harder to find with out getting ripped. I do appreciat all the feed back guys. Inow feel a lot safer with this drive to Kentucky. Stay tuned for the next adventure with the Jeepster. |
