Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 04-09-2005, 01:58 PM
clipin3g clipin3g is offline
puddering problem
my eclipse pudders betwenn 1 and second gears i figured it was my plugs and wires so i changed them from advanced. Still did not work so went to another shop and said advanced gave me german plugs so i bought some japanese from there. Worked alot better then before but still a little bit. then the wires advanced gave me shreaded while taking them out like 5 minutes after installing so returned them and placed stock ones back in there. so now i have new plugs with original wires still puddering alot less then initially. should i go and buy newer wires which are better then advanced or try somen else?
Old 04-09-2005, 06:07 PM
Tyrone Biggums Tyrone Biggums is offline
Re: puddering problem
roadraceengineering.com shipping will make you have to wait a few days, but its worth it.
www.Club3gse.com
Old 04-09-2005, 10:36 PM
Back's Avatar
Back Back is offline
Banned
Go get OEM shit from Mitsu! Its the best thing you can do. Mitsu has already done a really good job tuning this engine, and what they use is what is best. If you want to put some nice plugs in your car though you need to go with NGK Iridium. Dont let anyone tell you that there is a better plug. Go to any race track, or performance store and that is what they will tell you to get.
Old 04-10-2005, 01:19 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
make sure the plugs are gapped correctly. incorrect gapped plugs can cause the car to run rough
Old 04-10-2005, 07:56 PM
Re: Re: puddering problem
what do you mean by gapped?
Old 04-10-2005, 10:40 PM
the gap inbetween where the spark comes out and the metal piece( i forgot their technical names). there needs to be a correct gap between them. did you install the spark plugs yourself?
Old 04-10-2005, 10:48 PM
Back's Avatar
Banned
Oh god you didnt gap your plugs? You have to always gap your plugs with the exception of iridium plugs. This is why everyone needs to take at least one semester of autoshop!
Old 04-11-2005, 07:31 AM
for his sake, i hope a shop installed the plugs. i hope you didnt do it yourself.
if the gap is too big, then the incoming air will blow out the spark. this will cause the car to run horrible
Old 04-11-2005, 09:55 AM
thanx i will check that out and make sure it was done right
